If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
heatman101
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
no heat
tip....
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
Here
is a tip that will help you to figure out what is wrong with your
Microwave Oven....
Basic Microwave
Oven
Troubleshooting Tips
heatman101
