Hello, Mr. Ross.
I'll be more than happy to assist you with this and all of your other Uverse concerns.
First please write these codes down, these are the TV codes for your Mitsubishi TV,
0093, 0150, 0178, 0019 (we are going to do trial and error for these codes till we hit the correct one for your TV.)
Please turn the TV on and point your ATT remote control.
Okay, using your ATT remote control, please press and hold the TV button together with the "OK" button.
All four modes should flash twice indicating that we are programming your remote control.
Now, enter the 4 digit code and the selected mode (in our case it is the TV) should give a long flash.
Then press OK.
Try to turn your TV off and check if it would respond
If not, please redo the steps but this time use the other codes I provided earlier.
If these codes wont work we will do the automatic code finder if you are using the "black" AT&T Uverse remote control.
Using your ATT remote control, please press and hold the TV button together with the "OK" button.
Then press the "scan/ff" button repeatedly with atleast 1 second interval till it turns your TV off.
Press OK then try to turn your TV on again.
Whenever your remote won't respond, try pressing either the AT&T button on top of the remote before any other buttons or the TV button beside the ATT button.
