Well what kind of phone do you have? If its a older phone then your probably stuck with that tone unfortunately.Well what kind of phone do you have? If its a older phone then your probably stuck with that tone unfortunately.
You can't post conmments that contain an email address.
When you change the ring on your Motorola V360 from the standard ring to another of your choice, you give the phone a personal touch. Rings, or ringtones, are included with your phone. You can also download and install ringtones from a mobile content provider or your mobile service provider. The ring you select sounds anytime you receive an incoming call. You can change the ring at anytime through the Motorola V360's settings menu.
Instructions
1.Press the "Menu" key on your Motorola V360 and click "Settings."
2.Click "Ring Styles" and select "Style Detail."
3.Highlight "Calls" and press the "Change" soft key.
4.Highlight the ring you want to use on your Motorola V360. When highlighted, a brief preview of the ringtone will play.
5.Press the "Select" soft key to choose the ringtone.
6.Press the "Back" key to set the ringtone on the Motorola V360
Read more: How to Change the Ring on a Motorola V360 ' eHow.com http://www.ehow.com/how_8468915_change-ring-motorola-v360.html#ixzz1XEda3gRH
---a score of 4 is highly appreciated-----
---if you think this resolution is helpful kindly click on "YES"----
---you may also leave testimonial-----
Thank you for choosing fixya
Roger
Just look at the bottom of the phone, you will find ringer tone volume marked with low & high. Put it to low. For the manual, see the bottom-side of the phone to locate the model number & search the Siemens website for the manual.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings To select a ringing tone for voice calls, select Tones > Ringing tone. To select a ringing tone for video calls, select Tones > Video call tone. To set the ringing type, select Tones > Ringing type. You can also set the device to sound a ringing tone that is a combination of the spoken name of the caller and the selected ringing tone, when someone from your contacts list calls you. Select Tones > Say caller's name. To set the volume level of the ringing tone, select Tones > Ringing volume. To set the various alert tones, select Tones > Message alert tone, E-mail alert tone, Calendar alarm tone, or Clock alarm tone. To set the device to vibrate when you receive a call, select Tones > Vibrating alert. To set the volume level of the device keypad tones, select Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
You can change the Alert type by going to Tone setup: Select Menu > Settings > Tone Here you will have the option of changing the ring type. you can select Ring only or Ring and Vibrate or any other available options as per your choice.
Hope this information is helpful.
Your comments and ratings are highly appreciated. Please do not forget to rate this solution.
i dont know how to say it dude but its something inside the ps3 i dont know what its called but yours is probably burned or broken u can get it fixed for about 50 dollars if u have warranty on it or call sony and u can send it to them
Oh hell... you must be going nuts if its the ring tone I think you're stuck with. I loath the manual that comes with this system so here it is in English:
Press 'Prog'
Press 'Intercom' twice
Now you can either go through the different ring tones by pressing 'SEL' on the LCD screen or using the Up and Down keys on the circular pad on the bottom right of the phone.
Once you have the tone you like click on 'Enter'
Pick up handset and hangup to complete the process.
Obviously it's crosstalk from the supply for the LCD backlight supply into the audio amp...it's odd, because the supply should feed LEDs rather than a CF...but I'm thinking maybe a label in the phone got wet and is conducting your whine over to the audio bits. The general solution is to crack the case, find the audio circuits, and make sure there is no deposit linking the areas such as from water condensation, spilled coffee, soaked label, etc. You can hear when you've fixed it!
