SOURCE: cofee perks okay, does not stay warm.
http://www.abtecparts.com/westbend.htm
Try this to order all of your part needs!
SOURCE: West Bend 33600 heats to 178 degrees
Im sure one of the thermostats is a high heat thermostat but more than likely the element is covered with lime, I would put some diluted "Lime Away" and let it soak for a few hours then drain it and run clear water through it three of four times.
If this doesn't work for you then I would change the high heat thermostat.
SOURCE: is our West Bend 33600 commercial urn 100 cup
As far as I know it does not have a spring. (At least the one we have where I work doesn't have a spring and it seems to work fine without one. But the urn was there before I started, so maybe at one time it had one.) Replacement parts are available here, and they list a stem but don't mention any spring.
Hope this helps. Thanks for using Fixya!
Testimonial: "thank you very much!"
SOURCE: West Bend 100-cup commercial urn -33600. Need
You can download the manual for your West Bend coffee maker from this page:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=30&secid=54&linkon=category&linkid=62
Water Level Measure of Ground Coffee
100 cups 6 ¼ cups
80 cups 5 cups
60 cups 4 cups
40 cups 2½ cups
Do not make less than 40 or more than 100 cups of coffee at one time. Use electric perk or regular grind coffee; a filter liner is not necessary.
