Looks like your mowers have a little age on them. I recommend that you remove the decks for inspection. I bought one recently that the deck was rusted out in the middle causing it to flex and throw the belt. Check for good alignment all around and make sure that the blade guides around the pulleys are as they should be. If not that will cause them to eat the belt. Make sure everything moves as it should including the blade engagement mechanisms.
I hope this helps you get going.
