Fuji FinePix F10 Digital Camera Logo
Anonymous Posted on Sep 02, 2008
No power Fuji F10
Camera won't turn on. When charging the charge light stays on briefly then goes off as if to signal full charge, yet the F10 still will not turn on. Bought new battery, charged it and problem still exist.
  • fixyacom925 Oct 08, 2008
    Same here No RESET combination? Should I remove the memory battery inside?
Azam Ali
Level 1:
  • Contributor 31 Answers
  • Posted on Jan 05, 2009
Azam Ali
Contributor
Level 1:
Answers
31
Questions
0
Helped
4469
Points
45
The symptom of light staying on briefly then going off suggest the battery is dead. If you bought a new battery did you put it in correctly? turn it around and try again.
My coolpix L810 won't turn on. Green light comes on but goes out. Can't see screen. Lense was frozen but plugged into computer and closed.
have the battery full charge? sometime the battery is not charged although the charging indicator is full charge, maybe the battery is shorted out.
I have a Finepix xp50, with a fully charged, correctly installed battery, that won't turn on. It worked intermittantly for awhile. We have 3 batteries for this camera thinking it was the battery
Be sure your battery is in the right way. Try reversing it. My battery has 3 rounded corners and one square corner. The square corner goes against the latch.
Camera wont turn on, have tried charging battery but the red indicator light only stays on for a few mins? do you think i need a new battery
This just happened to me. I tested the battery using my multimeter and it is fulle charged. On a whim, I decided to remove the Memory card and voila! It turned on.
My camera wont switch on
Make sure or Check out following thing :-
1) Direction of your battery might be wrong, Check out and put it again.
2) Load new or fully charged battery.
3) clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
4) Turn ON the camera, again firmly.
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Camera power problems?
It's not the battery. It turned out to be a memory card problem.
I took out my old memory card and put in a new one. It started working properly after that.
Fuji F10 No power
You said that you changed the battery, did you put it in the right way around?.
I had exactly the same trouble, changed the battery (got it on ebay for £2.99) charged it and it worked.
Having said that, I closed the lense from external power. If the camera wont operate from external power then the camera is probably dead.
Camera Won't Charge
my finepixz3 got wet. but after a few days it worked! but when the battery ran out it wont charge. is it the battery? it turned on a few sec when its in the cradle but it wont last after a few seconds it would turned off. is it the battery or the camera itself?
Finepix f10 problem
Try holding in the power button on the camera with the charger connected to the camera & still plugged into the wall outlet. This may be a reset the manual doesn't tell you about or simply a weird fix for the same problem I had with my F10.
Fuji finepix f420 no live image/memory not storing data
seems as if you havent fully charged your battery not sure if im right about my solution but its worth checking
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
