Tip & How-To about Heating & Cooling
Here are tips to make sure you air conditioner is ready for the hot weather.
Check your Filters
A dirty filter can cause you system to have to work that much harder, and it's already working hard in the heat of Summer. Replace air filters that are dirty so that more air can flow through and help keep you cool.
Get Rid of Debris around your AC unit
Outside ac units are exposed to the elements year round and can be impacted by what is happening outside. Clean any debris off of your ac unit and away from the exterior. You may also want to protect it from the sun so that it doesn't get too hot and have to work even harder.
Upgrade to a Programmable Thermostat
A programmable thermostat allows you to set the temperature to a constant temperature while you are home. You can also have it adjust based on your habits, such as a warmer temp when you are away from the home and cooler when you are home. A programmable thermostat can also help with your energy bill.
Get more tips at Air Conditioner Maintenance Tips for Summer HVAC Instant Quote
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
