Tip & How-To about Sharp Office Equipment & Supplies
4 Simple Cost Saving Tips for Sharp and other brand Copiers/Printers
With the new year just around the corner everyone has goals in mind. Goals for themselves, and goals for their businesses to achieve. Goal #1 for most businesses is to reduce their operations costs and save money. The less money they spend on office supplies and printers the more they can reinvest into the business, or use for team building activities or parties. Here are some simple tips to save money around the office.
  1. Paper is expensive and eats up a lot of the office supply budget. Simply defaulting your print driver to print 2-sided will save you lots of money in the long run. Not only will it save money on the paper itself, it will half the time spent reloading paper in your copier(everyone's favorite thing to do! /sarcasm). Not to mention it's environmentally friendly. Who doesn't like being green? It's so easy to make this adjustment!
  2. Color printing is another bulky line item on the printer costs worksheet. Another simple change in your print driver settings can default your color printer to print in B&W. Whether you buy toner/ink outright, or you have a maintenance contract which includes your toner, this will save your office a TON of money. Personally, when I install print drivers on a customer's computer I always default it print B&W unless specifically told to leave it on automatic color.
3. Don't print that document unless you NEED a hard copy of it. I know this sounds like strange advice from a guy who makes his living from copiers and copies being made, but this is another initiative of most companies trying to "go paperless." While most of them slightly reduce their printing volume, they will NEVER be paperless, no matter how hard they try. Use programs like Adobe Acrobat, or the free PrimoPDF to convert your files to searchable PDFs and archive them for retrieval. If you want to use your copier to start storing your hard-copy documents in a searchable PDF take advantage of Sharp's OSA platform in conjunction with Drivve Image to make it a 1-2-3 operation. This is a very inexpensive system that works like magic.
4.
Get rid of your inkjet and small desktop laser printers. I always hear about the guys/gals who throwaway their printer and go buy another one when the ink runs out, because "it's cheaper than replacing the ink." This reasoning is ridiculous! What nobody tells these people is that they can lease an office copier AND have an all inclusive maintenance and toner contract for LESS THAN THEY SPEND ON INK for their Office Depot junk printer. New small businesses in particular are guilty of this. In a monetary break-even scenario the obvious choice should be the option that saves you time. Time is money.
If you're in Houston I'd be happy to come to your office and do a quick "printing audit" to see if I can save you money. Odds are I can. Let's start a business relationship. Contact me today to schedule a print audit
What you get by achieving your goals is not as important as what you become by achieving your goals." - Henry David Thoreau.
Meaning when we plan our goals its for a reason, whatever improvement we think or know it would make, However during the process of completing your goals we learn and change as a by-product of pursuing those goals. In other words the values/lessons/ and experienced at the end of reaching your goals could only have been obtained by the process of pursuing those goals and such lessons/values and experience are way often more valuable than the goal itself or the achievement of it. Also completing a goal provides a mental state of mind often not obtainable without pursuit and completion.
Good luck- hope this helps
https://www.6ya.com/mrmmike
3answers
How to set Goals in Google Analytics
In order to set google analytics goals you have to be the account admin and the click on "Analytics Settings" then click on "edit" and then you'll see "Conversion Goals and Funnel".
Next to each goal there is "edit" click on it and follow the steps.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
