20 Most Recent 2008 Ridley Auto Glide TT Questions & Answers
I own a '06 Ridley Auto Glide and It gives a few
You probably need to rebuild the fuel petcock, if parts are available. If the fuel petcock is only sold as an assembly you may have to replace the assembly. If it is a vacuum petcock, you may just have a cracked or broken vacuum line.
12/13/2010 5:31:28 PM • 2008 Ridley Auto... • Answered on Dec 13, 2010
0answers
Battery termanals coming lose
this time there was alot of smoke coming from under the seat. I found the Start Mod had a melt down. Now I'm still waiting for part to come. Has anybody had a similar issue? The bike is an'06 TT with only 710 miles. I bought it used with 660 mile on it.Let me start by saying that someone is not getting the the battery terminals tight to begin with. These are just bolts not Ridley bolts and should be tightened as you would tighten any bolt. If you find that bolts are continually getting lose there is a product called Loc-tite that can be applied to the threads to prevent loosening. The smoke is a different matter. Generally when this happens we find aftermarket lighting or changes in the original wiring. You now need to see a mechanic,
11/10/2008 5:03:36 PM • 2008 Ridley Auto... • Answered on Nov 10, 2008
Clutch
the engine dies due to (what seems to be) the clutch not fully releasing. When the engine is started it is OK. The driver clutch has about 2500 miles on it since new last summer and has been lubricated within the last 1000 miles. This doesn't happen all the time only once in a while. Any ideas??? The problem is in the drive clutch. It needs to be checked out. Sounds like a lose bushing in one or more of the torque pins holes.,,,
Type 2 belt change
I don't know of a green liquid in the motorcycle but there are directions for servicing your transmission on the Ridley Owners Club website. There are also directions for servicing your motorcycle. Check it out: http://www.auto-glide.com/
11/10/2008 5:03:35 PM • 2008 Ridley Auto... • Answered on Nov 10, 2008
Engine Cooling
wondered if the tool bag might interfere with the natural cooling of the engine. I didn't know and thought I would ask. I've got it in such a spot that the leather doesn't come in contact with the exhaust pipe so I got that item covered.I can't imagine that that would effect the cooling.,,
My 2005 Ridley Auto Glide wont start thoughts?
Question moved from Cars and Trucks. This says never jump the battery. It also says to loop the wires together so they don't get mixed up and to check they are tight. https://www.youtube.com/watch?v=VSblhcFnuFo More here https://www.google.com/search?q=2005+Ridley+Auto+Glide+won%27t+start ..
6/25/2022 4:35:07 PM • Ridley Auto... • Answered on Jun 25, 2022
I need suggestions on a taller motorcycle windshield
Made to measure, custom plastic windscreens https://www.google.com/search?q=motorcycle+windshield+mde+to+measure ..
10/16/2023 7:21:35 PM • Ridley... • Answered on Oct 16, 2023
2answers
Iso a wiring diagram for 2006 ridley autoglide TT
There should be
5/26/2023 3:04:15 PM • Ridley... • Answered on May 26, 2023
Having a problem with my ridley motorcycle
carb clean rebuild or replace and or needs tune up --
5/23/2023 11:30:14 AM • Ridley... • Answered on May 23, 2023
2answers
2006 Ridley auto glide classic will not hold a charge. Bought new battery and she started but as soon as it was off, no start agian. no lights nothing. Silence. What is causing this?
Doesn't sound like the bike is charging your battery. Check the voltage regulator and the stator.
2/6/2022 10:49:08 AM • Ridley... • Answered on Feb 06, 2022
I have a 2007 Ridley autoglide sport 750cc and I'm trying to change handlebars and can't find where to unplug the internal wires from the old bars to install the new bars. Help please
In my limited experience the handlebar wiring usually can't be unplugged but has to be disconnected from the handlebar controls and unthreaded from the handlebar.
6/27/2020 8:02:37 PM • Ridley... • Answered on Jun 27, 2020
0answers
Ridley brontes racing bike manual
Gak paham baha inggris ni
4/16/2015 1:57:45 PM • Ridley... • Answered on Apr 16, 2015
What causes my fat boy to idle just fine but fall on its face back fire and try to shut down while riding
Some common causes and potential solutions: Air/Vacuum Leak: If your Harley develops a vacuum leak in its air intake system, the air-fuel mixture becomes too rich. This can cause frequent stall outs, especially after the bike warms up. Vacuum leaks often occur due to dried-out or cracked air intake boots, faulty gaskets, or worn-out carburetor seals. When air escapes from the intake system, the fuel fills the empty space in the combustion chamber, altering the air/fuel ratio and negatively impacting combustion. Severe vacuum leaks can lead to excess fuel flowing into the exhaust system, causing backfiring and stalling while riding. Clogged Fuel Tank Filter/Fuel Injectors: A blocked fuel tank filter (due to coagulated fuel, moisture, dirt, or corrosion) impairs fuel flow, resulting in a lean air/fuel ratio. On fuel-injected Harleys, clogged fuel injectors produce similar symptoms. Regular maintenance, including cleaning and inspecting fuel filters, helps prevent these issues. Faulty Cam Chain Tensioner: A malfunctioning cam chain tensioner can affect engine timing and cause stalling. Regular checks and replacements are essential to avoid this problem. Faulty Cam Position Sensor: The cam position sensor plays a crucial role in ignition timing. If it malfunctions, it can lead to stalling and backfiring. Clogged Air Cleaner: A dirty air cleaner restricts airflow, affecting combustion efficiency. Regularly clean or replace the air filter to prevent this issue. Ignition System Failure: Faulty ignition components (such as spark plugs, ignition coils, or wires) can cause misfires, backfires, and stalling. Inspect and maintain these parts regularly. Compromised Battery Terminal Connection: Poor battery connections can disrupt electrical flow, affecting the ignition system. Ensure clean and secure battery terminals. Remember that diagnosing and addressing these issues may require professional assistance. Regular maintenance and timely repairs can keep your Fat Boy running smoothly on the road.
4/21/2024 6:14:37 PM • Motorcycles • Answered on Apr 21, 2024
Engine number location on a 2007 c90
Honda C90, or Suzuki C90? all questions need full 'year make model'. Google it plus 'engine number location'. ..
4/21/2024 2:56:52 AM • Motorcycles • Answered on Apr 21, 2024
Need circuit diagram for ARLEC 15e 6-24Volt 15Amp Electronic battery charger OR their later model BC58
I can't find a diagram. The small potentiometer on the control board likely serves as an adjustable component to fine-tune specific parameters. Here are some possibilities: Voltage Regulation: The potentiometer might control the output voltage. By adjusting it, you can set the desired charging voltage for different battery types (e.g., 6V or 12V). Current Limit Adjustment: It could be used to set the maximum charging current. Adjusting the potentiometer allows you to limit the charging current based on the battery's capacity and condition. Sensitivity or Threshold: Some potentiometers act as sensitivity controls. For example, it might adjust the threshold at which the charger switches between charging and maintenance modes. Setting the Potentiometer: Without the specific circuit diagram or detailed information about your charger, I recommend the following general steps: Observe the Potentiometer: Identify the potentiometer on the control board. Note its position and any markings (if present). Consult the User Manual: Check the user manual or operating instructions. It might provide guidance on adjusting the potentiometer. Trial and Error: If no specific instructions are available, start with the potentiometer set to its mid-position. Gradually adjust it while monitoring the charger's behavior (e.g., charging current, voltage). Observe how the charger responds to changes in the potentiometer setting. Fine-tune it based on your specific battery type and desired charging characteristics. Remember that precise adjustments depend on the charger's design and the battery you're charging.
4/20/2024 3:30:25 AM • Motorcycles • Answered on Apr 20, 2024
What is the length of lift cables on a 1993 model 2693 hilo camper and any info on what after market part to use ? thanks
The lift cables on a 1993 model 2693 Hilo camper are 30 feet,2 3/4 inches long and fit the standard height lift of 11 feet 8 inches high to the top of the overhead. The lift uses two cables. According to a Hi- Lo camper travel trailer forum, cable replacement is basically the same on all years and models, with the main difference being the length of the cables from model to model. You can use a cable cut chart to find what cable length you need for your camper, and you'll need to know your year, model name, and box (body) length: Lift cables typically wear out after three to five years, so it's important to replace them as needed and keep them regularly maintained.
4/12/2024 1:26:15 AM • Motorcycles • Answered on Apr 12, 2024
Mine is a 410JS 1000cc Santana, Spanish made. Mechanical fuel pump does bring no fuel to the carb. Want to shift to an electric setup. What is the best pump? Do I need an overflow-line?
The bike doesn't exist as written. https://www.google.com/search?q=410JS+1000cc+santana We are better with 'year make model 1000cc'. Better to not try and do better than the bike engineers. A mechanical pump runs when the engine is turning, an electric pump will run as soon as the key is turned and create pressure all the time. It would have to be an in tank electric pump or it will burn out. Electric pumps are cooled an lubricated by the fuel passing through it. If it is a carbureted engine, you are pressurizing the carb bowl. If injected, it may already have a fuel return. Check the mechanical pump for a torn diaphragm, they are easy to change. ..
3/22/2024 10:35:55 PM • Motorcycles • Answered on Mar 22, 2024
2008 Ridley Auto Glide TT Logo
7 questions posted
Top Ridley Experts
john h
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Ridley Expert? Answer questions, earn points and help others
View Most Popular
Auto Glide TT Ridley
  • Auto Glide TT Ridley
Most Popular Question
own 06 ridley auto glide gives few
  • Motorcycles
