20 Most Recent Ace Hardware Ace Foot Control Dimmer Questions & Answers
My dimmer doesn't dim. only
your dimmer is no good,either bad out of the box or you accidenty shorted it out when you put it in
6/13/2011 4:35:43 AM • Ace Hardware Ace... • Answered on Jun 13, 2011
2answers
How do I unblock a kitchen sink that still won't drain after I poured a huge bottle of Draino Max and 2 medium size bottles of Ace Hardware drain cleaner over a period of 3 days and as soon as I poure
The fact that you ran a 15ft snake into the drain begs the question How long is the run from your sink to the main drain? Next is this run vertical , horizontal? does it go round any bends on its way ? and how does it terminate in the main drain? If you are not on the ground floor most sink drains terminate in a soil stack riser and these connections are prone to "furring up" as they are slightly smaller in diameter at the joint point. If however you can follow the sink waste pipe to an open gird or capped drain check the route for damage as a loose coupling can easily cause a blockage if it is weeping. Again without more info' can only guess but if you are in a shared block check with the neighbours to see if they are having similar problems as it may be that the central riser is blocked. HTH.
1/1/2015 3:36:02 PM • Ace Hardware... • Answered on Jan 01, 2015
How to wire a three way dimmer
Generally it depends on the way the circuit is constructed. How its wired depends on which of the three boxes the main power supply goes to first. 99% of the time if you connect the light to the common on one switch and the power to the common on the other switch, the red runner only between the 2 switches and the remaining wires one on each switch it should work.
8/22/2014 4:00:17 AM • Ace Hardware... • Answered on Aug 22, 2014
0answers
Why wont the water go down when I turned the Garbage disposal on?!!
It sounds like your sink may be clogged. Try Draino or another such product and/or a plunger
12/31/2012 10:40:36 PM • Ace Hardware... • Answered on Dec 31, 2012
Where is the hex wrench spot on the badger 5 model 5-81 i cant seem to locate where it is
11-2-12If unit has slot, then it's located on very bottom in center.Or use a broom.http://waterheatertimer.org/images/Broom-inside-disposal-350.jpgCopy following link for steps troubleshooting garbage disposal:http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
11/2/2012 10:40:14 PM • Ace Hardware... • Answered on Nov 02, 2012
1992 ford ranger has fuel but no spark drove it parked it the next morning will not start
ave you pulled a plug wire off and cranked it to see if you are getting spark to the plugs? That would be where I would start.
1/3/2012 4:50:35 PM • Ace Hardware... • Answered on Jan 03, 2012
Stapler!!!!
The most expensive stapler ACE sells is $35-ish. If something is broken or if you can't get it back together, you may need to replace it.
5/24/2009 3:53:12 PM • Ace Hardware... • Answered on May 24, 2009
Manual for scorpion sl2800 generator
Yes
4/9/2024 2:32:16 AM • Electrical... • Answered on Apr 09, 2024
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/ Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error : * Press the Back arrow on the keypad - this step is to refresh the UIU ( the device) * Type # 75 # - this is to check the signal strength If it does not go back to the normal display *Type # 80 # - this is to refresh the meter Then lastly you can repair the meter and the UIU by # 36 # The above steps will work better if you are outside the house because the meters uses the radio frequency connection The above error will occur in instances of bad weather conditions or if there is load shedding or power failure If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again. SOLVED: Pole meter conlog rf con meter keep on freezing ... Jan. 10, 2017 Meter reading shows rF CON instead of units available - Fixya Jun. 24, 2018 SOLVED: Good day my conlog ip54 elecricity meter showd ... Oct. 6, 2018 SOLVED: Rf con error - Fixya Jun. 20, 2020 More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ... How Do I Load The Activation Token On My Conlog Prepaid ... Mar. 17, 2020 I Need A Technician To Fix This... - Nairaland / General - Nigeria Jul. 22, 2019 I Need Number Codes To Reset Memmcol Prepaid Meter ... Jan. 11, 2019 More results from www.nairaland.com
3/24/2024 3:42:46 AM • Electrical... • Answered on Mar 24, 2024
Wiring 3 lights 3 separate switches
Consult a qualified electrician.
3/23/2024 7:13:23 AM • Electrical... • Answered on Mar 23, 2024
Ace Hardware Ace Foot Control Dimmer  Logo
1 questions posted
Top Ace Hardware Electrical Supplies Experts
Mike Cairns
Mike Cairns
john h
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ace Hardware Electrical Supplies
Most Popular Question
dimmer doesn 39 t dim only
  • Electrical Supplies
