20 Most Recent
Samsung MD800SC Microwave Oven Questions & Answers
Ligh bulb change in samsung
The cover has to come off the microwave to access the bulb. There are several screws around the back and sides. Remove these and the cover should lift off, revealing the bulb. For your own safety, make sure that the microwave has been unplugged from the outlet for several hours before attempting this repair.
Light Bulb Change
If
there's no obvious removable cover over the bulb (most often on the
rear or side) and the owner's
manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a
microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The
screws you need to remove should be pretty obvious, but a special
driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the
screws back in the right holes, since some may be special grounding
screws.
Bulbs can be had in most
grocery stores, hardware stores, home improvement centers, and big box
or department stores.
Many models use halogen
lamps. You must not touch the new one with your bare skin, as the oils
will shorten the bulb life.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
Samsung Microwave repair
This would be the turntable coupler, and you can get it
here. The best way is to search by model number. If by chance you don't find it, call them at the number on their site.
You need to unplug power, then remove the bottom cover
of the oven. In some brands, you have to cut the motor cover off with snips, then use a
screw when reassembling it.
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
Microwave
If your handi, most likly you can go to http://www.repairclinic.com and entervthe model number, and get a replacement motor so you can replace it. If your not handi with rlrctrical, you can simply buy an inexpensive wind up turntabe at any super store.
