20 Most Recent
Danby DWC1233BL-SC MaitreD 12 Bottle Wine Cooler Questions & Answers
Tech digital radio
That's a good question! First we have to find out if the light is part of a low temp circuit. If it is then I would look at replacing a low temp switch if it has one. The fact that it's still keeping wine cool tells me it either doesn't have a (LTS) or it isn't working. If you can find out where the wires from the light are located I would just cut a wire and tape the loose end with electrical tape. Its likely that its nothing but a warning light. One other option is to black out the light with paint or tape.
8/27/2014 10:43:34 AM •
Danby...
Answered
on Aug 27, 2014
I have a simmons nuflex bed that is fine except the foot wont raise. Massage works on foot, but it just wont lift. No clicking or noises when using the remote
If the foot of your Simmons Nuflex bed will not raise, there may be an issue with the motor or the lift mechanism. Here are a few things you can try to fix the problem:
- Check the remote control: Make sure the remote is properly functioning and the batteries are not dead. Also, check that the foot lift button is not stuck.
- Check the wiring: Check the wiring between the remote, the lift mechanism, and the motor for any frayed or disconnected wires. If you find any damaged wires, they will need to be repaired or replaced.
- Check the lift mechanism: Inspect the lift mechanism and look for any visible damage or debris that may be preventing the foot from raising. Clean the lift mechanism and lubricate it with light oil.
- Check the motor: If the motor is not functioning properly, it may be preventing the foot from raising. If the motor is faulty, it will need to be replaced.
If you are not comfortable with these steps, or if the issue persists after trying them, it may be best to contact Simmons customer support or a professional technician for further assistance. They may ask you to provide your bed's serial number and other information to help troubleshoot the problem.
4/17/2024 2:20:33 AM •
Furniture
Answered
on Apr 17, 2024
