20 Most Recent
Siemens WD61392GB Front Load Washer / Dryer Questions & Answers
Why would the tub shake from side to side?
Hi Louise from retired Englishman in SW France,
Check and adjust the feet so that it is level first :-
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
7/30/2011 3:19:08 PM •
Siemens...
Answered
on Jul 30, 2011
I do not have a
Methinks you could do with a manual now and for the future as I'm sure it would act as translation!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
John C.
4/20/2011 3:27:44 PM •
Siemens...
Answered
on Apr 20, 2011
My siemens washing machine does not spin but the
Hi, I have a Siemens WXL166AGB washing machine that has started jolting violently when on the spin cycle, as if something is out of balance, never getting fully up to speed. Subequently it cuts short the spin cycle and leaves the clothes wet. Any idea what it could be. Thank you, Phil Vanes
4/7/2011 7:56:48 AM •
Siemens...
Answered
on Apr 07, 2011
