20 Most Recent Samsung HL-R5656W 56" DLP HDTV Questions & Answers
Where is "fan #2" in Samsung dlp hl-r5656w?
I don't know which is fan #2 but if you take the back off, you will see one fan right in front of you. The other is harder to get to. It's the black box inside the silver covering with the holes (in left lower part).My TV was acting up by having only one color showing until I let it cool down then it would work fine. I cut a hole in the plastic back cover and mounted a bigger computer fan. Just spliced it in the wires of the little fan. Fixed the problem
1/27/2013 5:58:41 AM • Samsung... • Answered on Jan 27, 2013
Purple and blue screen on dlp tv
Sounds like a problem with the Vertical Video Card. Have fun finding one. If your TV is still under warranty... send your TV off for repair.
10/3/2012 5:33:36 PM • Samsung... • Answered on Oct 03, 2012
Screen distortion shadow
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com Common Problem #1) Convergence has gone outProjection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem. Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems. 7859b01.jpge87380c.jpg 69189a5.pngSOLUTION #1What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.Common Problem #2) CRT Fluid is CloudyProjection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images. Picture of a set that needs the fluid changed.578ba6c.jpg TV set after fluid change65af323.jpg 69189a5.pngSOLUTIONWhat you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
3/9/2012 3:22:13 AM • Samsung... • Answered on Mar 09, 2012
Samsung lamp is stuck
HelloIt is best to get it service by the technicians from the authorised Hitachi service center, because,it light engine should be checked and cleaned. It is really a very skilled work, and can't be done without proper tools and sound expereince. Just call the service center and ask of service. OK.
11/26/2011 4:14:22 AM • Samsung... • Answered on Nov 26, 2011
Display is so dim that
When did you replaced lamp last time in this tv?
It seems its lamp replacement time as existing lamp is near to die.
Thanks.
8/21/2011 9:56:04 PM • Samsung... • Answered on Aug 21, 2011
The mother board always needs repair or change
if it's costing $100 or more a year in repairs, you would just be better off buying a new tv
3/5/2011 9:33:04 PM • Samsung... • Answered on Mar 05, 2011
My Tv's problem started with
The color wheel mneeds replacing. You can get replacement color wheels from www.tvrepairworld.com
3/4/2011 12:16:18 PM • Samsung... • Answered on Mar 04, 2011
My Tv's problem started with a loud whining sound
tomscientzas,
Sure do. You have a bad color wheel which needs replaced. I have a tip at
http://www.fixya.com/support/r4160054-replace_color_wheel_in_dlp_projection_tv
which explains how to repair you unit and where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
3/1/2011 9:43:57 PM • Samsung... • Answered on Mar 01, 2011
My HL-R5656W made a popping sound and the screen
hi,
Check the lamp colling fan is it working or not. Also check the connection on the lamp holder is proper or not, possibility of connector burning . then, you have to check the lamp power supply. check the fuse in it. if all these are ok then you have to change the lamp power supply.
ok
2/6/2011 5:14:50 PM • Samsung... • Answered on Feb 06, 2011
Pic will not come on
you need to replace a lamp to correct this issue
12/19/2010 3:02:11 AM • Samsung... • Answered on Dec 19, 2010
Got power but wont turn
seolphone
12/18/2010 9:29:23 AM • Samsung... • Answered on Dec 18, 2010
I forgot the passcode that
you will have to get in touch with samsung tell them the model and serial numbers they will give you another code hope this helps
12/11/2010 4:27:16 PM • Samsung... • Answered on Dec 11, 2010
My Samsung hlt5656W DLP tv will turn on and within
bad lamp
11/3/2010 3:14:36 AM • Samsung... • Answered on Nov 03, 2010
Samsung HL-R5656W 56" DLP HDTV Logo
Popular Tags
37 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
HL Samsung
  • HL Samsung
Most Popular Question
screen distortion shadow
  • Televison & Video
