20 Most Recent Intimus 280 Shredder Questions & Answers
Two gear which are working at end of each roller
what about the gears?
5/20/2014 8:10:57 PM • Intimus 280... • Answered on May 20, 2014
Shredder stops - red light off
Some shredders are great for thicker paper. If you put a thicker piece of card through, it should activate the switch located in the middle of the shred blades. The paper might be too light to push it forward. Also, if you click the feed catch beyond it's operating position, this can also stop the shredder with no lights.
1/27/2014 12:36:38 PM • Intimus 280... • Answered on Jan 27, 2014
0answers
0answers
0answers
Red indicator light always ON mode but the unit is
This can be caused by more than one problem.
The bucket it not properly placed under the shredder or the safety switch is stuck or bad. I am sure there is also other reasons the could cause the red light staying on.
12/26/2009 4:20:55 PM • Intimus 280... • Answered on Dec 26, 2009
Intimus 280 shredder noise
The 280 is notorious for buildup of paper in the cutting cylinders and strippers.
If you are technical, unplug from wall, disassemble top cover and clean all the debris. Check nylon strippers (white plastic) for damage.
2/24/2009 2:04:13 AM • Intimus 280... • Answered on Feb 24, 2009
Jammed Shredder with viewgraphs/sheet protector
Nope you have to take it completely apart to let the tension off the cutter rolls.
2/13/2018 12:52:56 AM • Intimus Office... • Answered on Feb 13, 2018
Intimus 602. shredder goes about 2 inchs and then goes into reverse and has a flashing red light
Clean the paper shredder teeth and make sure that there is not paper caught in it and try again to shred.
6/2/2017 6:15:53 PM • Intimus Office... • Answered on Jun 02, 2017
0answers
Intimus 280 Shredder Logo
Popular Tags
11 questions posted
Top Intimus Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Intimus Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Intimus Office Equipment & Supplies
Most Popular Question
intimus 280 shredder noise
  • Office Equipment & Supplies
