20 Most Recent Philips 42PFL3603D/27 42 in. LCD TV Questions & Answers
I have a Philips 42" TV mod 42PFL3603D/27 serial;YA1C0824019426 Does not turn on any more the red light at the bottom of the set does not come on either
check for bulging capacitors on the power supply board. you will have to remove the back cover from the television set to get a good look at the power board. If you do notice swollen capacitors, desolder the bad ones out and solder new ones in.
9/19/2016 3:23:56 PM • Philips... • Answered on Sep 19, 2016
Will not power on no lite either what board should i replace
http://www.shopjimmy.com/philips-272217100569-power-supply-unit.htm
11/23/2015 1:51:14 AM • Philips... • Answered on Nov 23, 2015
I have a 42PFL3603D/F7, and the tv doesnt turn on right away, it takes about 8 times for it to stay on. Any suggestions
Power supply is in need of repair. Pull out the power supply. You will find transformer (has blue tape). The location of this transformer is T701. Underside of this transformer, pin # EL41 is in need of a resolder.With a small screwdriver, scratch an area next and around this pin. With a hot soldering iron and solder...resolder this pin. Your TV will be fine. There are no capacitors to replace. This is one of the best power supplies built for Philips TVs. Thanks for asking, Matt of Martins TV.
10/11/2015 5:13:17 AM • Philips... • Answered on Oct 11, 2015
2answers
My Phillips 42FPL3603D/27 clicks constantly when
It sounds that the main power regulator board has the fault. Your TV need a through check up. It will be best to contact any service technician, or to authorized service centre for Philips. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
10/10/2015 6:35:11 AM • Philips... • Answered on Oct 10, 2015
2answers
Phillips tv 42pfl3603d/f7 when I turn on it makes
signal board
10/10/2015 6:24:17 AM • Philips... • Answered on Oct 10, 2015
2answers
Tv on and off switch stop working I can push the switch in the red light would blank off and on a than stop the tv never came back on
Check the module that the power cord connects to, look for swollen capacitors, probably 3-4 parts will have "bulging tops" Capacitor Lab Visual Signs of Capacitor Failure Bulging and Leaking Check the pictures on the featured link, look for this type of failure in your TV. You do need soldering skills to change the defective parts. Be Aware of the +- polarity on the parts you are replacing.
4/17/2015 5:46:57 PM • Philips... • Answered on Apr 17, 2015
Error message on my LCD
download proper firmware for your model from philips website and complete firmware upgrade. That should solve your problem.
3/25/2015 8:26:27 AM • Philips... • Answered on Mar 25, 2015
2answers
Need firmware update
www.philips.com/welcome --- you need to include the welcome.
2/28/2015 4:00:11 AM • Philips... • Answered on Feb 28, 2015
Has power but doesn't come on
most of the time the caps dry out do to heat. check power supply, valu on caps way off.
5/26/2014 8:02:54 PM • Philips... • Answered on May 26, 2014
Phillips HDTV 42PFL3603D/F7 screen is grey (after phillips power-up logo shows) when plugged in, will not power off, remote led blinks when used, but no change.
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/ Check the site in 'Mosaic' view. It will make search easy.
1/7/2014 3:23:01 PM • Philips... • Answered on Jan 07, 2014
0answers
Reset circuit
Be the first to answer 1/5/2014 3:38:22 AM • Philips... • Posted on Jan 05, 2014Be the first to answer
Blue screen on Philips 42pfl3603d/f7
same result with all inputs? check all your input cables & connections
11/30/2013 6:44:42 AM • Philips... • Answered on Nov 30, 2013
Turned on my Philips 42pfl3603d/f7 and you can see the images but everything is blue what part went bad and can I replace it my self
It sounds that the fault should be with its main digital board. To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts. Try and determine whether you can repair it by yourself.
11/29/2013 1:08:10 PM • Philips... • Answered on Nov 29, 2013
I have an older Philips TV, model no.
The main board is faulty. Contact any service technician.
10/7/2013 3:08:42 PM • Philips... • Answered on Oct 07, 2013
0answers
Had lightning hit near by and tv will not do anything. could it be the cord or is there a reset button?
it may have blown the shock diode on the power board check that and change it. it stops the tv from blowing up in a lightning strike. if it has worked it wil have just blown that and the fuse inside the tv and nothing els.
9/21/2013 7:12:09 PM • Philips... • Answered on Sep 21, 2013
Philips 42PFL3603D/27 42 in. LCD TV Logo
78 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
philips tv model 42pfl3603d 27 will turn
  • Televison & Video
