20 Most Recent
LG MG280 Cellular Phone Questions & Answers
Usb driver
Hello
you can download the software from
here
please vote for me
from
hkmthumma
3/15/2010 5:03:24 PM •
LG MG280...
Answered
on Mar 15, 2010
Can't get an instructional manual
If you click on the link and choose the Area as North America and then USA it will then give you the option to choose a product and if youselect CDMA Mobile Phone you then choose english as the language andthen type in your phones model number it will then display the manualyou are looking for.
http://www.lge.com/support/manual.jsp
Source: FixYa
7/20/2009 12:34:00 PM •
LG MG280...
Answered
on Jul 20, 2009
Can't save contacts on LG MG280
the country or the operator have nothing to do with the problem you have specified. try resetting you mobile to the factory settings.this is a good solution to almost all the problems in mobile phone.if the problem persists still , then contact us back. thanks for using fixYa!
5/26/2009 1:44:52 AM •
LG MG280...
Answered
on May 26, 2009
PHONE IS IN SPANISH
If you can make your way to the main menu, select settings, (whatever that may be in spanish, sorry!), then go under languages to select English. I had to have a rep. from the company I have my phone thru to do this for me.
12/29/2008 8:35:18 PM •
LG MG280...
Answered
on Dec 29, 2008
Lg mg2800 how to change from spanish to english
hello. i can guide you tru the menu and change the lenguage because i speak spanish. if its verizon just press:
click on menu
then click on ajustes/herramientas
then click on 5. ajustes del telefono or ajustes del tel
after that click on 3. idioma
finally click on the ingles option.
if its another carriage, contact me and a can guide you. good luck
12/11/2008 4:16:16 AM •
LG MG280...
Answered
on Dec 11, 2008
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
