20 Most Recent Gardner Bender GVD-505A Non-Contact Voltage Tester with Pocket Clip Questions & Answers
2answers
2answers
Is there a manual for a gb gvd-505a live wire
Gardner Bender does not offer support or online documentation for these small devices.
CLICK HERE to verify.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
8/19/2018 4:42:29 PM • Gardner Bender... • Answered on Aug 19, 2018
2answers
What kind of batteries?
That tester uses 2 (two) LR44 (1.5 volt) batteries.
http://www.aikencolon.com/assets/images/pdfs/gardnerbender/Testers.pdf
See p.143.
8/21/2014 2:05:55 AM • Gardner Bender... • Answered on Aug 21, 2014
We have a Gardner Bender Live Wire tester GVD-505A
Two LR44 button batteries.
10/17/2013 11:59:24 PM • Gardner Bender... • Answered on Oct 17, 2013
2answers
How to change batters on GVD-505A
It is NOT the tip that slodes off but the pocket clip. Just slide the clip up, away from the tip, and you will see the batteries.
12/20/2008 7:56:31 PM • Gardner Bender... • Answered on Dec 20, 2008
How to use Gardner Bender GMT-12P meter
The 12P is just a plain old style meter. This is the GMT-312P and should be close enough https://www.gardnerbender.com/-/media/inriver/GMT-312_USE.pdf?modified=20200714162511 or you can contact direct at bottom of the page. https://www.gardnerbender.com/en/p/GMT-312/5-Function-Analog-Multimeter ..
6/2/2021 3:45:11 PM • Gardner Bender... • Answered on Jun 02, 2021
Gardner Bender GST 224 C battery size
AA means double A , AAA means triple A, 9 volt has a double lead with two wires on it. which do you have?
12/24/2014 2:24:55 AM • Gardner Bender... • Answered on Dec 24, 2014
Testing amps with a gb GDT 294a
you need to connect your unit in DC Amps mode in series with charger when in use BUT be careful that anything over 10A will blow the fuse
10/31/2013 12:33:49 AM • Gardner Bender... • Answered on Oct 31, 2013
GDT-192A
what about it?
10/17/2013 11:57:58 PM • Gardner Bender... • Answered on Oct 17, 2013
How to set GDT-311 Digital Multimeter to x 1000 ohm setting?
The 20K setting is close to what you're looking for. The 200 scale is best to read 0 to 200 ohms, the 2K setting would be to read 200 to 2K, the 20K is to read 2K to 20K, the 200k range is for 20K to 200K and finally, the 2000K is to read 200K to 2000K or (2M) ohm resistance.Basically, start on the high range, and work your way down until there is only one (or none) digit after the decimal point in the display for the best accuracy. A 6,500 ohm value may display as .006 reading on the 2000K range, and as you can see, doesn't give a true reading of the actual value. I hope this helps!
4/19/2012 10:22:02 PM • Gardner Bender... • Answered on Apr 19, 2012
0answers
GDT-192A
Be the first to answer 2/12/2012 2:37:36 PM • Gardner Bender... • Posted on Feb 12, 2012Be the first to answer
Gardner Bender GVD-505A Non-Contact Voltage Tester with Pocket Clip Logo
15 questions posted
Top Gardner Bender Measuring Tools & Sensors Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Gardner Bender Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Gardner Bender Measuring Tools & Sensors
Most Popular Question
change batters gvd 505a
  • Measuring Tools & Sensors
