20 Most Recent MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Questions & Answers
2answers
Ihave a motorguide brute hyper 67 trolling motor
This is most often caused by a faulty 24 Volt, section, (usually damaged output semiconductors, or the drive?) in the speed controller, fault, the only "Fix" is replacement. Simply obtain the entire speed controller and replace it "En Bloc" as it were. You will need to also obtain a service manual so you can disassemble it and obtain the parts numbers for the replacement parts.Otherwise take it to a professional and ask for a "Quote" as to prospective costings and go from there.
6/23/2022 3:29:21 PM • MotorGuide... • Answered on Jun 23, 2022
2answers
On my standard motorguide trolling motor the
put the motor in the water and ensure that the propeller is at the rear. On the head of the unit (where the direction indicator is) push down and turn the round plastic plate (this plate has the direction indicator on it) clockwise until the direction indicator mark (mine is blue and is about one inch long) is in line with the alignment bar on the non-moveable part on the head. You will hear several "clicks" and this means that the indicator plate is clicking around to the proper directional alignment with the motor in the water.
9/5/2021 3:28:45 PM • MotorGuide... • Answered on Sep 05, 2021
3answers
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
6/13/2021 12:28:54 AM • MotorGuide... • Answered on Jun 13, 2021
0answers
0answers
Great White GWB50 from 1995,
It very likely has a power transistor to vary the current to the motor. I am guessing that transistor has a collector to emitter short. That can be verified with a common ohm meter on a low ohms scale.
11/26/2017 3:29:06 AM • MotorGuide... • Answered on Nov 26, 2017
0answers
0answers
2answers
I got a new 70 pound motorguide trolling motor.
Well if it goes in reverse, to me that would suggest that the batteries are wired in reverse? Either that or the controller has gone faulty?
1/1/2015 11:33:10 PM • MotorGuide... • Answered on Jan 01, 2015
2answers
I have a Motor Guide
I believe you may have a bad low voltage circuit board problem. I do not think they make the board any longer but you may be able to convert it to work by bypassing the circuit board. I am working on one now.
1/1/2015 10:46:56 PM • MotorGuide... • Answered on Jan 01, 2015
3answers
24 volt trolling motor (motorguide) not working.
You have a high resistance short either inside the wiring or the lower unit. This will cause a voltage drop. I would be very careful not to keep it connected too long cuz the battery is trying to keep up with the current demand and may explode.
1/1/2015 9:39:40 PM • MotorGuide... • Answered on Jan 01, 2015
2answers
I have a brute 567
check the power switch for voltage,, short it across the pins and see if the motor runs, if it does, replace the switch
1/1/2015 9:25:03 PM • MotorGuide... • Answered on Jan 01, 2015
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
294 questions posted
Top MotorGuide Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • MotorGuide Electrical Supplies
Most Popular Question
nned motorguide 46 lb thrust electric
  • Electrical Supplies
