20 Most Recent
Ingersoll Rand 25 CFM 175 Psi, 13 Hp Horizontial Air Compressor, ModelNo. 2475F13GH Questions & Answers
What are the maintainance action in machine
Maintenance activities should be done at so many hrs of run time. Your manual should list recommended service hrs. Telling you to change oil or filters every 3 months may be wrong. It all depends on how many hrs it has run. Maintenance items include air filters,belts,oil in both engine and compressor, fuel filter and battery if equiped on the engine.
Air dryer. Why is new compressor running hot?
There are several reasons for a compressor to run too hot, including high compression ratio, high return gas temperatures, and lack of external cooling. High compression ratios are the result of either lower than normal suction pressures or higher than normal discharge pressures.
I have an ir RA330E20 and the piston ring is worn
naturally there will be as it is called piston to cylinder clearance
you can get rings from e-bay if you know the diameter of the bore and the ring width
indicates that the poppet /reed valves are worn and not seal off properly or the head gasket/s are leaking
