20 Most Recent Great Plains Industries Gpi& Fuel Pump Questions & Answers
Fuel pump continues to run a min after car turned off on 1985 chevy Camaro 5.7 motor
CHECK FOR RECALL IGNITION SWITCH/REPLACE IGNITION SWITCH
12/30/2014 3:47:19 AM • Great Plains... • Answered on Dec 30, 2014
How to change a fuel pump on a mazda 98 b4000
Before throwing more and more parts at the problem, first thing to check is fuel pressure, if it's OK, then that isn't the problem. It could be------a plugged catalytic converter, a failing ignition coil, bad plugs, distributor cap, ignition rotor, cracked/defective dist. cap, ignition module. The list can go on and on. Start with the basics. When was the last time a major tune up was performed? Smog check? We can minimize costs by figuring out the real problem first. If you are adamant about the pump, it's in the gas tank and you will need to drop it out of the truck to change it. Good luck
12/4/2014 2:00:25 AM • Great Plains... • Answered on Dec 04, 2014
How do you R/R a fuel pump on a 2003 mazda tribute?
maybe rubber hose fron pump to unip pipe got corroded or sweeled up soo much wont hold presssure.
10/19/2014 6:50:04 AM • Great Plains... • Answered on Oct 19, 2014
Can I use a inline fuel pump
Of course, it's free country (unless you are in North Korea). Where would you like to use it? On an oil furnace, a weed wacker perhaps?
10/14/2014 8:33:40 PM • Great Plains... • Answered on Oct 14, 2014
Where can I change fuel pump by doing dropping tank or under back seat
Depends on what kind and year of car
10/11/2014 11:41:35 AM • Great Plains... • Answered on Oct 11, 2014
Fuel pump is not running but is good
fuel pump relay
9/14/2014 3:04:19 AM • Great Plains... • Answered on Sep 14, 2014
I have a 1994 Ford Fairmont Ghia V8 which will not start, there is pressure in the fuel line up to the engine but no fuel, what could be my problem? The car has done 180K.
Is there a pressure regulator on the fuel rail? Is the fuel pressure correct and is the volume of fuel correct?
8/28/2014 4:29:23 AM • Great Plains... • Answered on Aug 28, 2014
Would a evap emission control system leak cause fuel pump prpblems
unrelated. po442 check your gas cap, replace with oem, clear code and run it for a few days.
8/26/2014 6:42:58 PM • Great Plains... • Answered on Aug 26, 2014
1999 ford expiodition
use a pressure gauge to check pressure at the rail. Change fuel filter. Replace fuel pump if needed.
8/26/2014 6:35:35 PM • Great Plains... • Answered on Aug 26, 2014
My youkon does not want to start changed fuel pump
check the fuel pump relay
8/26/2014 6:24:13 PM • Great Plains... • Answered on Aug 26, 2014
2001 gmc sierra fuel pump wont turn on
-First check fuse and relay. If all are good then test continuity at pump connector for open. If not continuity then the pump is bad. replace new one. Good luck Mai Lor
8/26/2014 4:20:43 PM • Great Plains... • Answered on Aug 26, 2014
Will a fuel pump off of a 95 nissan pickup work on a 94 nissan pickup
89-95 should have most of the same parts. And so I would think so.
8/6/2014 2:10:20 AM • Great Plains... • Answered on Aug 06, 2014
WHATS THE BEST WAY TO REPLACE FUEL PUMP ON 1993 TOYOTA PICKUP
I would drive it to the junkyard and buy a newer truck. Easiest fuel pump change ever. 1993 is an old tool.
8/4/2014 2:30:25 AM • Great Plains... • Answered on Aug 04, 2014
2answers
Why will my1994 bravada not start?
line got clogged again? Check to see if it, the engine, is getting fuel . Go backwards for engine and see if fuel is gettign to fuel fiter, etc.
8/4/2014 1:13:08 AM • Great Plains... • Answered on Aug 04, 2014
Where is the fuel pump in a 1993 buick park avenue
In the gas tank
8/3/2014 10:27:54 PM • Great Plains... • Answered on Aug 03, 2014
I have a 98 Bonneville and its giving all the classic symptoms of a bad fuel pump but my inlaws say its vapor locking
This sounds like vapor lock to me, especially if you've had any exhaust work done since then. The key with vapor lock is temp of course, FPs will go out hot or cold. Check the fuel lines for points near high heat.
7/27/2014 3:26:38 AM • Great Plains... • Answered on Jul 27, 2014
Whats the fuel pressure 70 corvett
5-8psi, assuming it is still running a carb.
7/26/2014 11:23:24 PM • Great Plains... • Answered on Jul 26, 2014
Great Plains Industries Gpi& Fuel Pump  Logo
111 questions posted
Top Great Plains Industries Garden Experts
Jay Finke
Jay Finke
john h
Are you a Great Plains Industries Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Great Plains Industries Garden
Most Popular Question
change fuel pump mazda 98 b4000
  • Garden
