20 Most Recent
Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45 PSI, 12 Volt Questions & Answers
Pumps
as soon as your finger is off the trigger
Insufficient Pressure From Pump
Take the strainer at the end of the hose on the tank off. Throughly clean it. I used an old tooth brush, then ran hot water through it several times. Also drained the tank and flushed it out 3-4 times with fresh water, then ran fresh water through the pump for several minutes
Hope this helps
