20 Most Recent
Cooper Industries Weller Soldering Iron, Slim, for WES51, Uses Eta Tips Questions & Answers
I have two WU81 Weller
Perhaps this fuse should be a "T" type or delayed acting (antisurge fuse) . If the fuse has been replaced by an "F" fast acting fuse then this could explain why they are blowing.
2/14/2011 9:13:20 PM •
Cooper...
Answered
on Feb 14, 2011
WES 51 LED not flash to indicate ready
the iron has a temp probe inside the pencil, most likley the problem. also these have problems with the powersupply but usually it won't heat if its a power supply problem. best guess would be the sensor in the pencil
7/7/2009 4:34:55 PM •
Cooper...
Answered
on Jul 07, 2009
Soldering iron troubleshooting
Bits: It's useful to have a small selection of manufacturer's bits (soldering iron tips) available with different diameters or shapes, which can be changed depending on the type of work in hand. You'll probably find that you become accustomed to, and work best with, a particular shape of tip. Often, tips are iron-coated to preserve their life, or they may be bright-plated instead. Copper tips are seldom seen these days.
4/20/2009 4:40:26 PM •
Cooper...
Answered
on Apr 20, 2009
Burned resistors
I have the same problem with the Mighty Mig...Did you find these resistor values?
Century 100 wire feed welder free download manual
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiX5_3Gt66DAxVCC3kGHUEmCY0QFnoECA0QAQ&url=https%3A%2F%2Fwww.manualslib.com%2Fproducts%2FCentury-Wire-Feed-100-4113584.html&usg=AOvVaw3kmdPZSNde6Hkk_kq3bVxZ&opi=89978449
Deltaweld 350 with help 700 code ?
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwiJm8Xqtq6DAxUvrokEHSvtAyUQFnoECA4QAQ&url=https%3A%2F%2Fwww.fixya.com%2Fsupport%2Ft29927508-deltaweld_350_help_100_code&usg=AOvVaw1Zz2ud-ECJTvyBdf5Zm-bJ&opi=89978449
