20 Most Recent Olympus E-520 Digital Camera with 14-42mm and 40-150mm lenses Questions & Answers
Camera not turning on
Remove the battery and charge it again. If you only can make just a few shots with the battery and it stops again, think of buying a new battery. Special when you have not used the camera for a long time, the second and third charge can be better. If not the battery is on its end of life.
12/31/2013 12:43:36 PM • Olympus E-520... • Answered on Dec 31, 2013
WHEN I SWITCH ON MY
Take out the SD card and slide the button on the side in the opposite direction it is in now. That should fix it.
Hope it helps
Steven Cumming
Please leave positive feedback :-)
6/5/2011 8:07:33 AM • Olympus E-520... • Answered on Jun 05, 2011
I have had the my olympus 520 camera almost a
Which card are you using the XD card or a compact flash card? If you have an external reader, confirm that the card can be read on a computer still, or if you have another card, try that to see if it works. It is possible that in reinsterting the card you may have damaged the contacts in the socket. More likely with the Compact Flash than XD card.Very nice camera, sorry to hear you having problems, hopefully it is nothing serious. Media cards can fail. Have you already backed up the pictures that were on the card? If so, try to reformat the card if you have a connection for it on your PC.
3/11/2011 5:42:00 AM • Olympus E-520... • Answered on Mar 11, 2011
My camera won't focus when I'm trying to take a
Try taking pictures of close-ups at 14mm setting on 14-42mm or buy the close-up lens that you can use on the filter ring of your zoom lenses lenses.
6/17/2010 12:44:01 PM • Olympus E-520... • Answered on Jun 17, 2010
2answers
Olympus e520 will not turn on
try to rest your camera and see if that works
5/30/2010 11:29:19 AM • Olympus E-520... • Answered on May 30, 2010
How do I get the alignment grid lines to display
U will go to menu, than Setting 1, than go to DISP/PC, than Fram Assit and Select GRID. Than go back and press INFO Button on Camera Few times. Ur grid will appears.
3/27/2010 3:31:40 PM • Olympus E-520... • Answered on Mar 27, 2010
Can't take a picture without abundant light
Does it work okay in bright sunlight without a flash? If so, try changing the options to factory default.
3/23/2010 12:19:05 AM • Olympus E-520... • Answered on Mar 23, 2010
E500 + fl50
you don't have to see the flash on the screen.
if the flash is on tll than he adjust itself to the camera setting
9/4/2009 4:11:00 PM • Olympus E-520... • Answered on Sep 04, 2009
I don't see my Olympus Electronic flash FL50 is
is the flash on tll ?
9/4/2009 4:05:55 PM • Olympus E-520... • Answered on Sep 04, 2009
Why is my compact flash write protected?
The write protection is usually enabled by flipping an extremely tiny switch on either the side of the card or the adapter you may be using. Write protection keeps your data safe from being over-written.
5/14/2014 5:43:08 PM • Olympus E... • Answered on May 14, 2014
What does the card error mean
Can be lots of things. Would have been handy, if you had told what card you are using. Your camera can work with CompactFlash, Microdrive and xD-Picture cards. If you did not insert the card(s) you are using, correct, or you removed the card in a wrong way, you could have damaged the cardholder, causing an error you probably can't repair yourself. The CF and Microdrive you can remove by pressing the eject button. The xD-Picture card you can remove by pressing in the card, and release it. The card comes out. Then you could have damaged the file system, by opening the card cover, while the card access lamp was blinking. What ever card was in, the filesystem can be damaged. Then you can have two cards in, Both, o CF of Microdrive and a xD picture card. Some settings are required for the camera, to know hat card it should use. If you have an Microdrive, the drive can be damaged, by a magnetic file, or the drive just stopped rotating. A micro drive is actual a miniature spinning hard drive. First check if the memory card is inserted correct. Eventually, remove it and check all contacts, on the card and in the camera. Then try formatting the card. If you think there could be important pictures on the card, put it in a external card reader and use a recovery program, to see you can recover the pictures on your computer. Programs can be found on the net. If you can't format the card, check if you have a Microdrive. If so, try to replace that with a CF or xD card. I hope something is to any use for you. Next time, please give us some more details. I know you exactly see and know what is not working, but we only can use your description. And only what you give us.
2/16/2014 11:53:00 AM • Olympus E... • Answered on Feb 16, 2014
0answers
How to clear an sd card
The best way to clear your card is to format it. There should be a "Format" command somewhere in the menu system, probably under "Setup." Since you neglected to specify the model of your camera I'm afraid I can't point you to the exact location.
6/26/2012 5:00:24 PM • Olympus E... • Answered on Jun 26, 2012
2answers
Hi! can i use xD 2GB TYPE M+ CARD WITH OLYMPUS STYLUS 300 DIGITAL?
  • The Olympus Stylus 300 camera works with xD-Picture cards, including the 2GB Type M+ card. But it's important to make sure the camera can use that particular type and size of xD card by checking the camera's specifications and list of compatible devices.
4/3/2024 5:36:15 AM • Olympus Cameras • Answered on Apr 03, 2024
My Olympus fe320 has a blurry screen & takes blurry pics. Is there a fix / solution to this?
Could be a steamed up lense or just dirt from storage. It is over 10 years old so possibly past its best by date but take it to a photographic shop and ask them for an estimate.
9/20/2023 4:02:06 PM • Olympus Cameras • Answered on Sep 20, 2023
Olympus E-520 Digital Camera with 14-42mm and 40-150mm lenses Logo
20 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
E Olympus
  • E Olympus
Most Popular Question
get alignment grid lines display
  • Cameras
