Have a problem with Zenith 37
HDTV. Medel number: Z37LZ5D As wathcing TV, along with 'pop' sound,
TV went dead. LG service center gave an advice to unplug the power cord and press ON/OFF power switch about 1 min. Then plug power back and turn on the TV. Well, the green light blink for a while and solid green, but still no screen, no audio. Search the Web and someone suggested to replace Power Supply Board which will fix the problem. Again, search the Web and came out with Power Supply Board. LG Electronics/Zenith 'Power Supply Assembl' with $124.95 from PartStore.com. Is it the right solution? Do I have to replace entire Assembly Board? not just replacing some fuse? Any cheaper way to do? If I have to replce PSA board, any suggestion to how?
Comment posted on Apr 22, 2009
I have a basic knowledge of electric and electronics, such as rewiring entire house for renovation and assemble entire
computer from scratch.
Actually, the TV belongs to my father and the problem that I stated was based on what he told me.
So the question is based on the symptom that I posted, how sure are you that the problem is the Power Supply Board?
Is it good to order PSB?
Comment posted on Apr 23, 2009
Purchased 2 and half years ago. Expired one year warranty.
Zohail,
This is LCD TV.
There is no problem with the wall socket nor current.
I put other appliances on same wall socket and worked.
It has to be internal problem.
As I mentioned on the main post, there was a 'pop' sound while watching and TV went dead.
Turn on remote control, there is blink green light and then green stays on, but no sound, no screen.
Turn off remote control, light turns red.
Comment posted on May 14, 2009
I fixed the TV.
Orderd power supply board which cost me $136.51 total.
Replacing was simple.
Just removed the rear panel cover then electronic board housing cover.
Took power supply board with all the connector cables and replaced with new one.
Problem was a transformer connector which got burned and blow up the plastic cover.
But no problem with fuse and capacitors.
Thanks all for advises.
