20 Most Recent
Philips Pronto TSU9400 LCD Touchscreen Remote Control Questions & Answers
My 2 year 9400 charging
Hi,thanks for posting your Question..
Most times, when you keep using a
TSU9400 remote which needs to be charged, and you always remove the charger from it and fix back when you need to charge it again..It makes the mouth of the port where you insert the pin charger to go weaker every time..
So in the issues you might need to replace the port where you insert the charger into..Or you can test out another charger first to confirm if it will charge properly..
If it does not charge,that means you might need to contact your repair canter in your area for help.
It might also be a problem of firmware update too.. You can use the link below to know more about firmware update..
http://files.remotecentral.com/prontopro/index.html
Hope it helped...
The screen of my pronto
we have the same problem and it cannot be fixed by the person we bought it from, did you ever find a solution
Philips model tsu9400 is not
hi,
If you have a digital multimeter,set it into a dc voltage measurement.then measure the charger terminal of atleast 5-12v dc.if you have a reading then check the contact between the remote terminal and the charger you can lift out the charger terminal to exposed it to the remote and easily connects when you insert the remote.
If you dont have a voltage reading on the charger terminal then you have to repair the charger.this require opening the cover.make sure to unplug the charger to the wall socket before attempting to repair....use a soldering iron then resolder all the components inside the board..speciallt the charger terminal...check also the fuse..good luck and let me know so Ican give you further solution.
I have a Philips Pronto TSU9400, it is about 2
Hello and Welcome to FixYa!
Well it can be a battery fault, as well as loose connections between the lcd strip and the main board circuitry. You have to double check both possibilities one by one starting directly from battery first...
Concerned.
Frozen Pronto
Hi
Thankyou for the offer, but I finally fixed it.
I searched high and low on the Internet and finally found a document that led me to believe it was WIFI problem. I reset (switched off and on) the WIFI receiver, and removed/replaced the battery in the remote control and hey presto. it worked and is still working.
Daryl
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
