20 Most Recent
TruTech SMP-1 GBL MP3 Player Questions & Answers
Player isnt turning on
Try resetting the device it’s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds
or
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer’s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
The earphones are not working properly. the voice
Try using another pair of headphones to test if the problem is with the headphones. If the problem persists, you may need to contact their customer service for repair. It may be cheaper to simply replace the unit.
No Drivers came with my TRUTECH SMP-1GBL
hi =)
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
How do I delete songs off of my mp3 player in a
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,
right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
When i plug in my mp3 player and i download songs
Make sure you read and find out what are the attributes of the MP3 files that your unit uses. For example, It might not play stereo files, or the quality of the MP3 might be too high. check you manual and make sure that you are using the correct attributes that the manufacture is calling for.
TruTech MP3 1 GB Player freezing up after no more than 1 min
Please try to reset the player and see whether it helps.
This could be done by inserting a paper clip into the reset hole and press and hold for about 20 seconds.
If this does not help it could be software related issue. Upgrade the firmware via manufacturer's web site.
