20 Most Recent
Amcor 3900 GPS Receiver Questions & Answers
I have an Amcor 3900
Unfortunately Amcor was one of the many companies that put out GPS units, and then never really took care of the updates. Then in January of 2009 Underwriters Laboratory issued a press release stating that Amcor was fraudulently using their symbol on the 3900 as the units were never submitted for testing. UL advised anyone who owned a unit should immediately return it to the the point of purchase. Their website is now shutdown, so you cannot even try and get an update from them. If you search around on the web there are a few hack sites that claim to have updates. They of course do not guarantee in any way that the update will work with your unit.
Hi, my amcor navigation wont
Hi openheaven02,
The only thing you can do with this issue is to reseat the SD card and press the hidden reset button in the side with the stylus. This will help you fix the problem. However, there might be some data that will be wiped out when you do this.
Hope this helps.
Thank you for using FixYa.
I received my AMCOR 3900
The Amcor 3900 gps is a direction finder. Once you get it going, it contains directions and maps to anywhere you might want to go.
Here is Amcor's contact website: http://www.amcor.com/contact_us/enquiry/contact_enquiry_form.html
I loaded it to pop up the email form for you. Just email them and ask for an owner's manual for the 3600/3900 or ask any questions you have, such as how to get it going.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
they went out of business years ago, but the device can be hacked ,it runs windows ce, same as pocket pc's so you can make it run igo or other navigation software, go here and check this forum out
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=101292
if you found this info useful please vote for me
Need clip that attaches gps
I looked on Ebay and found several items that match your request.
I hope this helps you out. Any positive feed back would be greatly appreciated.
Removed from packageing. plug into charge aux
- Firstly, switch On and switch OFF the device.
- If it doesn't works then,I recommend you to go to the Authorized Service Center to get your device repaired.
- Moreover ,since your device is just new ,therefore you can easily get it repaired as it may be either guaranteed or under warranty.
