20 Most Recent
Gold Medal 2148 Popcorn Maker Questions & Answers
What was the use date on the Gold Medal flour?
You are probably concerned about the recent Salmonella issue?
The product is the UNBLEACHED all purpose flour:
Gold Medal Unbleached All Purpose 5LB Flour Package UPC: 000-16000-19610-0 Recalled Better if Used by Date: 20APR2020KC
The "use by date" is ink dot printed on each package, usually toward the bottom of the package somewhere.
Trying to find kettle wiring drawing 3255
To order a manual from the factory the part# is 67834. Depending on how old this is , those kettles and or similar design had a issue with the nut comming loose that holds down the thermostat thight to the bottom of the pan. The loose nut would then bounce around in there until it touches a elect.connection and ground at the same time. It will short circuit the kettle and end up welding itself in place . so when you turn the kettle on it trips the circuit rite away. you have to dissasemble it and remove it . there is a new locking type nut avalible to replace it.
Popcorn burns
If the corn/ oil ratio is correct , check the thermostat operation . It is burning because it's in there too long from lack of heat to make it pop.
Gold Metal Popcorn Machine 1618 ETS
That is a 16 oz popper with big eye electonics, With a Target Store Neon sign. This model was only sold to Target Corp.
There is no question here.
