20 Most Recent
Graco Alano Travel System - Fortune 7F01FOR3 Stroller Questions & Answers
Front wheels do not lock on
get new retainers that lock onto the axle to stop the wheels from falling off
they look like a washer with internal teeth that expand as you push them on but dig in when trying to pull off
How do you remove canopy from graco sweetpeace
You need to remove the center of the part that connects to the chair. Use a thin screwdriver into the center and then pry each of the two tabs outward from the center. As you unhook it, you will be able to pry it out and then the attachment mechanism will pull off
How to remove seat wire, after putting it in wrong on the Graco uno2duo stroller?
This question was posted a long time ago, but no one answered it correctly. If you put the wire in backward, look on the end of where the wire was inserted. You made have to move the fabric to see it. There are holes. Use something to push in the metal piece that is showing as you pull out each side of the wire. I used a house key to push in the button while I removed the wire.
