20 Most Recent Pioneer Avic-F940bt High Performance Gps Entertainment System With A 6.1 Inch Touchscreen Questions & Answers
How to change time on Pioneer Carrozzeria avic hrv22 it has only Japanese, that's what my car's audio/GPS system and, please, help me out with changing language to English and finding maps?Thanks!!
Changing the language and updating maps on a Pioneer Carrozzeria AVIC HRV22, which typically comes with Japanese language settings, can be a bit tricky, but it's possible. Here's a general guide:
  1. Locate the Settings: First, try to navigate through the menu to find the settings option. It might be represented by a gear icon or a wrench icon.
  2. Use a Translation App or Guide: If you can't understand the Japanese menu, use a translation app on your smartphone to translate the menu options. Alternatively, you can search online for a guide or manual in English for your specific model.
  3. Change the Language: Once you've located the settings menu, look for an option related to language settings (???? in Japanese). Select it and then choose English (or ?? in Japanese). Confirm your selection.
  4. Update Maps: Updating the maps might require accessing a specific section of the menu, typically labeled something like "Map Update" (????). Once you're in that section, follow the prompts to update the maps. This might involve connecting the device to a computer and downloading the updated maps from the manufacturer's website.
  5. Follow On-Screen Instructions: Throughout the process, pay attention to any on-screen instructions or prompts, even if they're in Japanese. Sometimes, the navigation buttons or layout might remain consistent regardless of the language.
  6. Reset if Necessary: If you accidentally get stuck or lost in the menus, there might be a reset button somewhere on the device. Pressing this button will restore the device to its factory settings, allowing you to start over.
If you find it challenging to navigate the menu or if the options are not readily understandable, you might want to seek assistance from someone who understands Japanese or consult a professional who specializes in car audio/GPS systems. They can guide you through the process more efficiently.
4/22/2024 1:07:16 PM • Pioneer Car... • Answered 3 days ago
Help wiring Pioneer Ca9pa V6 650 from Mazda Atenza
When the unit was in the Mazda, it was run and monitored by the Body Control Module computer. Moving dedicated units from one vehicle to another seldom works the way you expect. https://www.google.com/search?q=pioneer+ca9pa+v6+650+wiring+diagram ..
2/25/2024 10:29:32 PM • Pioneer Car... • Answered on Feb 25, 2024
2answers
4500 pioneer equalizer how to find the four wires
Four wires ... which four wires.
2/4/2024 8:29:07 AM • Pioneer Car... • Answered on Feb 04, 2024
Can I connect my smartphone to the Pioneer AVH-500EX?
See page 37 of manual. Procedure is given there. AVH-601EX_600EX_501EX_500EX_OpManual062918.pdf (pioneerelectronics.com)
1/7/2024 9:56:38 AM • Pioneer Car... • Answered on Jan 07, 2024
Pioneer 3308 MOSFET 50 watt x 4 owner manual please?
Model number is not specific enough unless you just want details on the 3308 MOSFET component.
https://www.google.com/search?q=Pioneer+3308++manual
SM3308NSQA MOSFET. Datasheet pdf. Equivalent
All Transistors. Datasheet https://alltransistors.com > mosfet > transistor Equivalent. Type Designator: SM3308NSQA. Type of Transistor: MOSFET. Type of Control Channel: N -Channel. Maximum Power Dissipation (Pd): 29.8 W.
SM3308NSQA Datasheet, N-Channel MOSFET.
DatasheetsPDF.com https://datasheetspdf.com > pdf > Sinopower > SM330... SM3308NSQA MOSFET Datasheet pdf, Sinopower, SM3308NSQA Features · 30V/35A, RDS(ON) =7.3mW(max.) @ VGS =10V RDS(ON) =10.5mW(max.) @ VGS =4.5V · 1.
SM3308NSQA
?????? http://www.sinopowersemi.com > temp > SM33... PDF N-Channel MOSFET. • 30V/35A,. RDS(ON) =7.3m?(max.) @ VGS =10V. RDS(ON) =10.5m? ... SM3308NS QA : SM. 3308N. XXXXX - Lot Code. Assembly Material. XXXXX. • Power ...
3308A Datasheet, N-CHANNEL MOSFET.
DatasheetsPDF.com https://datasheetspdf.com > pdf > KIA > 3308A 3308A MOSFET Datasheet pdf, KIA, KIA SEMICONDUCTORS 80A,80V N-CHANNEL MOSFET 1. Features n RDS(ON)=6.2m?@VGS=10V n Lead free and gr.
1/2/2024 5:04:54 PM • Pioneer Car... • Answered on Jan 02, 2024
Do you have a wiring diagram for a Pioneer DXT-X2769UI ?
If you need the wiring diagram for connecting to your automobile wiring, see page 12 of the manual available from Pioneer here: https://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DXT-X2769UI_OwnersManual070714.pdf . I hope this helps. Cindy Wells
12/9/2023 1:39:00 AM • Pioneer Car... • Answered on Dec 09, 2023
3answers
Wiring diagram for pioneer deh-s31bt to amp and 4 speakers
Hi Mark, please download from pioneer website, or put in a search on google for this models user manual. cheers.
12/4/2023 9:18:01 AM • Pioneer Car... • Answered on Dec 04, 2023
My Pioneer PD-M40 plays the discs if the disc cartridge is already inserted when powered on. But if I power on the machine and then insert the disc cartridge nothing happens.
The issue you're experiencing with your Pioneer PD-M40 suggests a potential problem with the disc loading mechanism or the sensor that detects the presence of the disc cartridge. Here are some troubleshooting steps you can try: 1. **Clean the Disc Cartridge and Player:** Dust or debris on the disc cartridge or inside the player may affect proper disc loading. Remove the disc cartridge and clean both the cartridge and the player carefully with a soft, lint-free cloth. 2. **Inspect for Obstructions:** Check for any visible obstructions inside the disc loading mechanism or around the edges of the disc cartridge slot. Ensure that there is nothing blocking the path of the cartridge as it is inserted. 3. **Check for Proper Alignment:** Ensure that the disc cartridge is properly aligned when inserting it into the player. Misalignment may prevent the player from recognizing the presence of the cartridge. 4. **Try a Different Disc Cartridge:** If you have access to another disc cartridge, try inserting a different one to see if the issue persists. This can help determine whether the problem is specific to the cartridge or the player itself. 5. **Power Cycling:** Turn off the player, unplug it from the power source, and wait for a minute or two. Plug it back in, power it on, and then attempt to insert the disc cartridge to see if the issue is resolved. 6. **Test with the Lid Open:** Power on the player with the lid open and observe the disc loading mechanism as you insert the disc cartridge. Check for any unusual movements, sounds, or signs of misalignment. 7. **Lubrication:** If the player has not been used for an extended period, lubrication on moving parts may have dried out. Consult the user manual for recommendations on proper lubrication or contact Pioneer customer support. 8. **Contact Pioneer Support:** If the issue persists and you've exhausted the troubleshooting steps, it may be advisable to contact Pioneer customer support or seek assistance from a qualified technician. There could be an internal issue that requires professional attention. Always refer to the user manual for your Pioneer PD-M40 for model-specific instructions and recommendations. If you don't have the manual, you may be able to find it on the Pioneer website or by contacting their customer support.
11/19/2023 9:04:37 PM • Pioneer Car... • Answered on Nov 19, 2023
Wiring diagram for a Pioneer avic- D3 car stereo
https://www.pioneer-car.eu/eur/support/manuals/19184
9/18/2023 4:29:41 AM • Pioneer Car... • Answered on Sep 18, 2023
Pioneer PD-F605 File Type Compact Disc Player. Where do I purchase the control and output cable for my PD-F605 and to listen to CDs - What kind of speakers do I need.
Question edited for clarity. Greetings from Mississauga :>D My research shows it just needs a standard RCA lead to connect. However you realize this is just a standalone CD player and needs an amplifier as well as speakers? It has no amplification of its own, it just puts out an audio signal. When connected to a Pioneer System Audio Amplifier, the control cables allow you to control the CD Player from the Amplifier remote control as they cable connect to that amplifier. The Line Out connections are for the RCA cable and supply the audio data to the amp. https://www.google.com/search?q=PD-F605+cables You just have one small part of a composite audio system. Regarding speakers, most are 8 ohm. you can spend $50 used or $60,000 for Bowers and Wilkins Nautilus. I have a pair of Wharfedale Linton speakers that I bought from the UK factory that you can have for $450 CDN :>) Top of the range. ...Watch the videos with black squares on YouTube.
9/16/2023 4:42:53 AM • Pioneer Car... • Answered on Sep 16, 2023
Need to know which wire powers the factory amp please?
The answer lies in the 'year make model' and the only clue you give us is 'truck', so here you go. This website lists them all. One problem with modern vehicles is that the Body Control Modules monitors the stereo because it does other features, like giving warning sounds via the speakers. Playing with wires is not wise because the BCM uses a 5 volt computer network to relay data and it sounds like you may have given it 12 volts?
2010 Dodge Ram 1500 Car Stereo Install Diagram
modifiedlife https://www.modifiedlife.com > 2010-dodge-ram-150... Our 2010 Dodge Ram 1500 radio wiring guide shows you how to connect car radio wires and helps you when your car radio wires not working. It also shows you the ... ..
8/16/2023 2:31:15 PM • Pioneer Car... • Answered on Aug 16, 2023
Pioneer avh-p5200dvd power button behind faceplate "broken"
If the power button behind the faceplate of your Pioneer AVH-P5200DVD is broken and the copper jumper is lost, there might be a few things you could try:
  1. Contact Pioneer Support: Before attempting any repairs yourself, it's a good idea to reach out to Pioneer customer support. They might be able to guide you through potential solutions or suggest authorized repair centers where you can get professional help.
  2. Check for Replacement Parts: You could try searching for replacement parts for the specific model of your Pioneer unit. The copper jumper you're referring to might be available as a replacement part. Check online marketplaces, electronics repair shops, or even Pioneer's official parts store.
  3. Jumper Wire: If you have some experience with electronics, you might consider using a small gauge jumper wire to bridge the connection that the power button makes. This could potentially be a temporary solution, but keep in mind that modifying the internal components of electronic devices can be risky and might lead to further issues if not done properly.
  4. Professional Repair: If you're not comfortable working with electronics, it's advisable to seek help from a professional electronics repair technician. They have the expertise to diagnose the issue accurately and carry out repairs safely.
  5. Temporary Workaround: If the above options aren't feasible, you might consider leaving the power button in the "on" position (if possible) and using the unit's remote control to power it on and off. This would bypass the need for the physical power button.
Remember that tampering with electronic devices can void warranties or lead to further damage if not done correctly. If you're unsure about any steps, it's best to consult with a professional technician.
8/9/2023 10:46:17 AM • Pioneer Car... • Answered on Aug 09, 2023
How do I remove the trim plate and unit on pioneer deh-p6600
Maybe this will help https://www.manualslib.com/manual/310720/Pioneer-Deh-P6600.html#manual
8/8/2023 8:51:57 PM • Pioneer Car... • Answered on Aug 08, 2023
Pioneer Carrozzeria Avic MP33. I have this unit and it is in Japanese! How do I change it to English. Volkswagen Up!
Question edited for clarity and 'make, series, model and number' in correct order. My searches lead me to believe that you have a model that was made for the Japanese home market and only comes in Japanese. The advert for it is in Japanese. No English Manual listed.
??????? AVIC-MP33 ?? - carrozzeria
????????? https://jpn.pioneer > portablenavi ·Translate this page ??????????????????????????????????????????????(AVIC-MP33)?????????????? There are a few models like this. Sometimes they can be changed by executing a Firmware Update. Write to Pioneer in Japan. Write in Japanese first and in English below. Be very polite, they like that. Try the help in the videos for this range. But I think you are stuck. https://www.google.com/search?q=pioneer+carrozzeria+avic+mp33+japanese+to+english+language ..
7/18/2023 3:28:26 PM • Pioneer Car... • Answered on Jul 18, 2023
2answers
Need a wiring diagram for a pioneer avh270bt radio
RED +ACCESSORIES YELLOW- BATTERY + BLACK- GRND BLUE-ANTENNA BROWN-MUTE{ TO GROUND IF USE} BLUE/WHITE-AMP TURN LIGHT GREEN-PARKING BRAKE PURPLE/WHITE REVERSE CAMERA ORANGE- DIMMER ORANGE/WHITE -ILLUMINATION. WHITE+ WHITE/BLK --}LEFT FRONT GRAY+ GRAY/BLK--}RIGHT FRONT GREEN+ GREEN/BLK--}LEFT REAR PURPLE+ PURPLE/WHITE--}RIGHT REAR
6/25/2023 8:26:11 AM • Pioneer Car... • Answered on Jun 25, 2023
How can one change the language settings in the Pioneer Carrozzeria AVIC-RZ03 from Japanese to English?
Try this website. It has a short video showing you which buttons to press when it is in Japanese. https://www.timescar-rental.com/en/beginner/gps.html
6/8/2023 7:23:34 AM • Pioneer Car... • Answered on Jun 08, 2023
Pioneer Avic-F940bt High Performance Gps Entertainment System With A 6.1 Inch Touchscreen Logo
2 questions posted
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Car Audio & Video
Most Popular Question
change time pioneer carrozzeria avic
  • Car Audio & Video
