20 Most Recent Mongoose 26" Mens XR-75 Mountain Bike Questions & Answers
0answers
There are no threads on the crank arm to screw a pedal on. What do you do now?
1. replace the crank. 2. Purchase a Heli-Coil or other brand at an auto store. It looks like a tube with threads on both sides that will screw in to the stripped hole and there by install new threads. Bring the pedal to the auto store to make sure it will thread in to the "female" threads on the Heli-coil. The problem is the pedal is steel and the crank arm is soft aluminum. Also, people damage them because one pedal is normal thread and the other is reverse thread meaning you turn clockwise to loosen.
7/29/2014 6:41:42 PM • Mongoose 26"... • Answered on Jul 29, 2014
Trying to assemble mongoose back tire and chain
I am sorry I could not find a manual for your Mongoose.I will suggest you go to the following websitehttp://www.youtube.com/watch?v=2j1gSwhsVN8You can find numerous videos for your bike repair. in YoutubeBud
9/25/2012 3:48:29 AM • Mongoose 26"... • Answered on Sep 25, 2012
Does front handlebars go up higher on my Mongoose Maneuver Mountain Bike?
Yes, all bikes have handlebar height adjustment.
How to Adjust the Handle Bars on a Mongoose Mountain ...
DIY Mountain Bike https://www.diymountainbike.com > adjust-handle-bar... This is done by loosening the bolt and clamp on the front of the stem. Insert a 6mm Allen wrench into the bolt head and turn until the handle bars roll freely.
How to Raise Handlebars on Mongoose Mountain Bike
mtbrules.com https://mtbrules.com > how-to-raise-handlebars-on-mo... Oct 2, 2022 - You can adjust the handlebars from front to back by loosening the clamp bolt in the stem's front. Insert a 6 mm Allen wrench into the bolt head.
How to Raise the Handlebars on a Mongoose
SportsRec https://www.sportsrec.com > Fitness > Strength Training Jun 29, 2011 - Other options for raising Mongoose handlebars are adding a new riser bar, which can give 1 to 5 inches of height for your handlebars. A steer- ... Missing: maneuver ‎' Show results with: maneuver
Product Manuals
Mongoose https://www.mongoose.com > pages > product-manuals The Mongoose owner's manual contains important safety, performance and maintenance information. Read the manual before taking your first ride on your new ...
1/25/2024 5:59:26 AM • Mongoose Cycling • Answered on Jan 25, 2024
Serial number HCII 08974.
Hope this helps....https://shop.re-rides.com/blogs/news/mongoose-serial-number-for-bmx-mid-school-new-schoolAnother link...copy and paste...https://duckduckgo.com/?t=ffab&q=mongoose+bike+serial+number+decoderBest to you.
6/30/2023 10:59:47 PM • Mongoose Cycling • Answered on Jun 30, 2023
2answers
How do I download manual for 29" mongoose
https://www.mongoose.com/pages/product-manuals
7/19/2022 12:48:30 PM • Mongoose Cycling • Answered on Jul 19, 2022
Whats the worth of a mongoose wit the serial number fsd11d33485
http://www.vintagemongoose.com/frame/serials.php This will tell you more about your bike. The value is what someone is willing to pay for it.
6/26/2022 6:19:56 PM • Mongoose Cycling • Answered on Jun 26, 2022
My Mongoose Canaan rear axle needs servicing. There is a flange on top of the cone nuts. How do I remove it?
Question moved from Cars and Trucks. In my day there was two small holes and you used a special wrench. videos https://www.google.com/search?q=mongoose+rear+axle+assembly ..
6/5/2022 6:09:19 PM • Mongoose Cycling • Answered on Jun 05, 2022
Freecoaster assembly diagram for Mongoose Mode bike. This bike has caged bearings on the outsides.
Request the assembly diagram from Mongoose.
3/25/2021 11:04:39 PM • Mongoose Cycling • Answered on Mar 25, 2021
I have a mongoose bike lock I need to get unlocked and reset the code. Can you help?
Take it to a locksmith or buy another one.
11/18/2020 4:04:33 PM • Mongoose Cycling • Answered on Nov 18, 2020
Is there way I can raise the handlebars on my Mongoose ledge 3.1? is there a way I can raise the handlebars up?
Mongoose full-suspension mountain bikes, like the Ledge 3.1, have a little bit of height adjustment for the handle bars. See the manual at https://www.mongoose.com/pages/product-manuals . The current link to the appropriate manual is https://p.widencdn.net/brqquy/OMMGFS-1_Mongoose_FullSuspension_OM . Start at page 18 (20 of the manual in the browser) and determine the type of stem on your version of the bike. The quill stem version has minimum insertion marks that must be below the top of the headset and not visible. For the threadless stem version of the mountain bike, you adjust where the handlebars clamp onto the steerer tube. However, this is very imited since there should be only 1/8" to 3/16" gap between the top of the handlebar stem and the steerer (stem) tube. The is where the top cap and bolt to replaced on the handlebar stem and thread into the steerer tube. I hope this helps. Cindy Wells
1/26/2020 5:19:36 PM • Mongoose Cycling • Answered on Jan 26, 2020
2answers
I would like to know the size of the frame on the Mongoose 29in Torment Men's mountain Bike
Hey, Local bike shop determined that both wheels were defective. I took the junk back to Walmart and got a refund... PROBLEM SOLVED!! Check out https://gearly.org/ for more info. Thanks.
1/23/2020 1:04:03 PM • Mongoose Cycling • Answered on Jan 23, 2020
Why won't my pedals move forward on my Mongoose bicycle. They are frozen and it is a brand new bike.
If you have no idea what's wrong then you probably would not be able to fix it either. If a brand new bike then contact the seller for help, see if there's a bike co-op in your town, or go to a bike shop for diagnosis.
7/11/2019 12:07:24 PM • Mongoose Cycling • Answered on Jul 11, 2019
Adjust rear shock(soften) mongoose ledge 2.1
Understanding Sag In order to let the suspension work properly, we allow some of the rear-wheel travel to be used when supporting the rider's weight, this is called 'sag'. The basic idea is to have around 10-20% of your bike's total travel as sag. This allows the rear wheel to drop into dips in the trail and maintain contact and traction. Adjusting Sag on Rear Suspension Changing the amount of sag in the rear suspension is done by increasing or decreasing the spring rate of the rear shock. The rear shock's body is threaded and you will notice there is a nut on one end of the spring. Turning the nut in the direction that compresses the spring will increase the spring rate and reduce the amount of sag. Turning the nut in the direction that expands the spring will decrease the spring rate and increase the amount of sag. Never turn the nut to the point where there is space between it and the spring, this may cause damage to the shock.
6/16/2019 2:22:27 PM • Mongoose Cycling • Answered on Jun 16, 2019
2answers
How do i fix the rear brakes ofmy mongoose mode 270 so that they work
Can't help without more info, but try this link - follow the procedures that apply to your type of brake. https://www.parktool.com/blog/repair-help/?area%5B%5D=48
3/18/2019 1:00:36 AM • Mongoose Cycling • Answered on Mar 18, 2019
2answers
I need a owner'sed manual for this model
2/28/2019 1:56:11 AM • Mongoose Cycling • Answered on Feb 28, 2019
Mongoose 26" Mens XR-75 Mountain Bike Logo
3 questions posted
Top Mongoose Cycling Experts
vince
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
View Most Popular
Mongoose Cycling
  • Mongoose Cycling
Most Popular Question
no threads crank arm screw pedal now
  • Cycling
