20 Most Recent
Fossil Leather Multifunction Black Ip Ana Digi BQ9297 Watch for Men Questions & Answers
How do i replace the strap with the new one
You can usually but a watch strap from you local shop and they will fit it for you.
If you particularly want a Fossil strap, then you can get one fro them by going to their web site "fossil.com", select "watches", then "men" or "women" and scroll down the page and near the bottom you will find a number of alternative straps that you can buy from them.
You can have it fitted by a local watch shop if you do not wish to fit it yourself.
Brand new watch won't work
Check your users manual if your watch have two batteries. If yes, you need to replace digital part battery.
If your watch has only one battery, your digital screen or plate is defective. Bring it back to the retailer and ask to replace for the decently working watch.
But first of all try to fiddle with all pushbattons- sometimes it helps.
Battery for fossil blu ch-2495
Fossil battery replacement sizes are usually a 2430 (CR2430), 371 (SR920SW), or 377 (SR626SW).
https://www.fossil.com/en-us/******/how-to-change-a-watch-battery
What does the 18 inside a square on the back of my fossil watch mean?
The 18 inside a square on the back of your Fossil watch likely indicates that the watch case is made of 18-karat gold. This is a mark that is used to indicate the purity of gold. 18-karat gold is 75% pure gold and 25% other metals. This mark is typically used on jewelry and watches to indicate the quality of the materials used.
I Have a fossil 10
Your watch is 12 hours out of step.
The date changes every second time the hour hand passes 12 O'clock.
Your watches' second pass is at midday instead of midnight, so to make it operate correctly, you need to wind it on 12 hours. The date will then change at midnight.
What kind d of battery does a fossil blue am-4065 take?
Hi Cassandra.this is what i found out from the net.Most hybrids are compatible with any CR2430 coin cell battery, which allows them to hold a charge for 4 to 6 months. Swapping in a new coin cell lithium battery can be done easily and in just a few simple steps, plus CR2430 batteries are available from most retailers that sell batteries.
