20 Most Recent
British Telecom Contour 50 Corded Phone (212796) Questions & Answers
Bt contour 50 phone is completely dead
Yeah, the internal battery is probably exhausted. You can replace it with a new one, which you can get on eBay, but you probably need to know how to solder it in
How easy is it to
HI,I have just replaced the battery on a similar phone today (not a BT one, but a "Payphone Link 20", its belgian counterpart).It was a bit tricky as the battery is soldered on both sides of the circuit board, but the battery was replaced in a matter of minutes and the phone works fine now.I wouldn't recommend this to the novice however. You need good soldering skills + equipment, and basic knowledge of how to handle a circuit board without damaging it (i.e. short circuit or electro-static discharge).If you're not sure, I would advise you to get it done by someone familiar with electronics repair. Otherwise there are several companies that could fix it for you : you send them the front of the phone by mail, they replace the battery, clean and check the phone, and send it back to you.
I have a BT Diverse 6450 DECT answering machine
try this
press the menu button
select answering service scroll down until you get global , press menu button scroll down until you get vwmi press menu button move to yes , click menu then end that should put the light off
Bt complaints procedure
why are you still paying for a service you are not getting
stop payment from your account and make them come to you
yes put it in the hands of watch dog and put it on face book and any other media that you can as bad publicity hurts even the most ignorant of companies
Bt caller display
hi I am 01278652763 and i have a problem on my caller display line, you told me to contact you on this address for further information. my email is
[email protected] thanks
