20 Most Recent
Avanquest MyDeluxeInvoices & Estimates for PC Questions & Answers
I have backed up MY Deluxe invoices every use and
There could be several causes, but my first thought is a defective storage unit. I assume you backed up to an external drive? They usually don't last but a few years. If the corrupted data is on the same hard drive as the program, I would suggest checking your hard drive for errors.
1/16/2018 2:49:34 PM •
Avanquest...
Answered
on Jan 16, 2018
I am thinking of purchasing and I wanted to know
This is an accounting application so it should have as the calendars an dates of service should be there as default.
Your best bet is to contact Avanquest directly and ask one of their sales staff. Click on the link below for Avanquest contact.
http://www.avanquest.com/USA/corporate/contact/
Regards.
7/20/2010 2:32:43 PM •
Avanquest...
Answered
on Jul 20, 2010
My file won't open and the backup isn't working
I have had similar problems with an older version of MyInvoices, yet I first get a message saying, "Customer file is corrupted." I actually was surfing to see if anyone has had similar problems with the customer file. I have had to go to the extent of restoring things on another computer and then putting it back on my original computer. I have even, at times over the years, had to delete all of the files from the one computer in order to restore it from the other.
However, there is sometimes an easy fix to your problem: the program intermittently creates "Safe" versions of your file. These versions can be found in the "Safe" folder (which is located in the MyInvoices folder of the MySoftware folder under Program files). There are numerous "Safe" folder which are likely numbered. You can check the date and time that they were automatically created and select the most recent one. However, restoring it this way will cause you to lose any information that you inputted after this date/time. Hopefully you will have a very recent one and will be able to access your data. Hope this helps!
10/28/2009 8:48:17 PM •
Avanquest...
Answered
on Oct 28, 2009
EasyInv.exe missed
I TOOK THE FILE FROM ANOTHER COMPUTER THAT HAD THE SAME PROGRAM IN IT, JUST MAKING COPY-PASTE TO THE RIGHT FILE LOCATION WITH A FLASH MEMORY.
11/13/2008 7:37:30 PM •
Avanquest...
Answered
on Nov 13, 2008
How to uninstall snap do
Some times if you go to safe mode you can delete items because they're not in use bu the system.
5/5/2016 1:50:11 PM •
Avanquest...
Answered
on May 05, 2016
