20 Most Recent
Kohler NET HP COURAGE XT-7 SERIES VERTICAL ENGINE Questions & Answers
Wont spray
I hope the engine wont spray... if it's a pressure washer thats not spraying the name of the unit would help... but does it build pressure but doesn't spray - check the wand does it even build pressure ??? no - replace pump
Kohler engine 241 as no spark
there is a piece next to the flywheel tha has a magnet and grabs resistence that may need replacing. I had this happen on mine. call your local repair shop and ask. I found the answer to mine on youtube and replaced it in about an hour,
Spark and fuel but engine wont fire
Usually a solenoid or battery issue. may be the flywheel too. It does turn and the flywheel on top spins horizontally, yet it will not catch? if so then it may need a solenoid next to the flywheel which grabs resistence as the flywheel spins. cheap fix and on youtube.
