20 Most Recent
Stinger Streamlight XT Rechargeable Flashlight with Fast DC Piggyback Charger Questions & Answers
My stinger light will not
All batteries go bad eventually. Heat is bad for them, as well as freezing. Slow charging is better than fast charging. Often if I take the built in batteries in to a electronics place, I can get cheap replacements that can easily be soldered in. Hobby shops are good for this, because they go through batteries so quickly on radio controlled toys.
2/24/2011 5:52:58 AM •
Stinger...
Answered
on Feb 24, 2011
Light does not come on. It flickers on and off.
If the flickering is constant and is not affected by bumping etc then it probably is in some type of mode. maybe you can change this mode by slightly pressing and relaeasing the power button when it is on. On the other hand maybe the battery terminals are abit lose.
1/30/2011 12:46:28 AM •
Stinger...
Answered
on Jan 30, 2011
Light will not come on
How long have you had this light until it was defective. I believe you're having a switch failure. You should send the light in for evaluation, switches are covered under a lifetime warranty. ;)
8/28/2009 9:27:08 AM •
Stinger...
Answered
on Aug 28, 2009
Rechargable Stinger new bulb is dim orange
Could possibly be a bad switch, I would also get that battery tested out also. If you still have a receipt it should be covered under warranty. If not try sending it in anyway. Limited lifetime warranty does not include bulb, or batteries but, anything else on that Stinger should have a lifetime warranty. Of course that excludes abuse. Check out the website www.streamlight.com and go to FAQ for a nearest Authorized Service Center or send it directly to Streamlight. Address also listed on the website. Hope that helps ;)
8/28/2009 9:07:02 AM •
Stinger...
Answered
on Aug 28, 2009
Where can I find replacement parts for my rechargeable lantern?
It's great that you're looking to revive your rechargeable lantern! Here are some steps you can take to find replacement parts and ensure your lantern is in working condition:
- Check with the Manufacturer: Start by contacting the manufacturer of your rechargeable lantern. They may offer replacement parts for your specific model, including the light tubes. You can inquire about replacement batteries as well.
- Search Online Retailers: Look for online retailers specializing in selling replacement parts for lanterns and flashlights. Websites like Amazon, eBay, or specialized outdoor equipment stores may carry the replacement light tubes you need. Make sure to check if they ship to Canada.
- Visit Local Hardware or Outdoor Stores: Explore hardware stores, camping supply stores, or outdoor equipment retailers in your area. They may have replacement light tubes or similar products that are compatible with your lantern.
- Consider Universal Light Tubes: If you cannot find the exact replacement light tubes for your lantern, consider purchasing universal light tubes that fit the size and specifications of your lantern's sockets. Be sure to measure the dimensions of the sockets and compare them with the specifications of the replacement tubes.
- Test the Battery: Before purchasing replacement parts, it's a good idea to test the battery to see if it still holds a charge. If you have a compatible charger, you can try charging the battery and observing its performance. If the battery no longer holds a charge or shows signs of leakage, you'll need to replace it.
- Inspect for Damage: Since the lantern has been in storage for several years, carefully inspect it for any signs of damage or wear, especially around the battery compartment and electrical components. If you notice any corrosion or damage, it's best to address those issues before using the lantern.
By following these steps, you should be able to find replacement parts for your rechargeable lantern and get it back into working condition. If you encounter any difficulties, don't hesitate to contact customer support or seek assistance from a local retailer.
4/16/2024 9:58:57 PM •
Camping,...
Answered
on Apr 16, 2024
Do you need special hiking shoes for going on long walks?
Whether or not to buy hiking shoes really depends on what kind of walking you plan to do and how often.Hiking boots are helpful for rougher terrain and for gripping. If you plan to mostly walk on flat ground, you can consider getting good walking shoes instead.
1/25/2024 4:10:25 AM •
Camping,...
Answered
on Jan 25, 2024
