20 Most Recent FreeMotion XTC Recumbent Exercise Bike Questions & Answers
I am trying to get side cover off of my freemotion 330 r bike i have removed the pedal and all of the screws i am doing this so i can adjust the tension
To remove the side cover of your Freemotion 330 R bike, follow these steps:
  1. Turn off the bike and unplug it from the power source.
  2. Remove the pedal on the side you want to remove the cover from.
  3. Locate and remove all screws that are holding the side cover in place. There may be screws under a cap or sticker.
  4. Carefully pry off the side cover from the bike frame. It may be held in place by clips or other fasteners, so use caution and gentle force to remove it.
  5. Once the side cover is removed, you should be able to access the tension adjustment mechanism.
Note: Make sure you keep all screws and parts in a safe place, and follow the manufacturer's instructions for adjusting the tension.
2/26/2023 5:21:57 AM • FreeMotion... • Answered on Feb 26, 2023
Our Freemotion Incline Trainer Treadmill Model #FMTK74810.0 won't increase speed but when we hit the Up arrow the fan will blow faster??
It sounds like there might be a issue with the control board of your treadmill. The control board is responsible for managing all of the functions of the machine, including the speed of the belt and the operation of the fan. If the fan speed is increasing when you press the up arrow, but the belt speed is not, it suggests that there is a problem with the control board that is preventing it from sending the correct signals to the motor to increase the speed. To resolve this issue, you may need to have a technician take a look at the control board and repair or replace it if necessary. Before calling for service, you can also try resetting the treadmill by unplugging it from the wall for a few minutes and then plugging it back in. This can sometimes resolve issues with the control board. If the problem persists, I would recommend contacting the manufacturer or a professional repair service for assistance.
2/12/2023 1:03:22 PM • FreeMotion... • Answered on Feb 12, 2023
My Freemotion 11.9 Treadmill has a high pitched noise coming from the electronic board. What could the issue be?
Question edited for clarity and fix the model number, no 'o'. Question moved from Televisions Category to maker Category. Try and find a repairer for the board, this make does not have a maker website, so made in China. I can't think of anything on a PCB that would make a noise. https://www.google.com/search?q=freemotion+11.9+parts ..
1/15/2023 2:05:10 AM • FreeMotion... • Answered on Jan 15, 2023
I have a 350R freemotion that became unplugged. Believe it or not I have spent two days trying to find where to plug it in. Please help
Hi, The bottom front portion of the bike should be where the power insert is located. If you have further issues, please reference the bike manual diagram or you can call the manufacturer at 1 800-201-2109. Thank you.
10/15/2022 10:16:52 PM • FreeMotion... • Answered on Oct 15, 2022
My freemotion i5.3 incline trainer shut off while I was walking on it and now it will not turn back on.
I have a Freemotion i5.3 Incline Trainer. When I run on it at 4+ MPH it makes loud bangs when my foot land on the platform. I usually walk on it at higher incline and just recently started running on it. The bangs are much louder at 0% incline than at higher inclines for the same speed. What might be the problem?
1/24/2021 4:50:05 AM • FreeMotion... • Answered on Jan 24, 2021
Model 330R recumbent bike. Why is it making a humming sound?
Made in China. Cheap transformers and electrical clutches. Trace the hum, disassemble, replace humming unit with padding underneath. A piece of card or felt will suffice. https://www.amazon.com/review/R20B8A5N87L2ZB ..
10/30/2020 5:32:18 PM • FreeMotion... • Answered on Oct 30, 2020
How lubricate 350R Freemotion cycle Bikes
3/27/2020 7:15:51 AM • FreeMotion... • Answered on Mar 27, 2020
Freemotion model F610 squat machine
What is the question?
1/14/2020 12:26:23 AM • FreeMotion... • Answered on Jan 14, 2020
Freemotion f5.6 Elliptical Strider display buttons not working/responding.
If one of the buttons is stuck, none of the buttons will work. Try using a hair dryer to free the stuck button. the heat (use low) will cause the button to expand and might free the button. Otherwise, the consoles are not repairable, and are a straight replacement item. Call Icon Fitness for parts pricing.
3/7/2019 4:52:56 AM • FreeMotion... • Answered on Mar 07, 2019
Cannot change resistance on my freemotion 335R bycicle
If it is battery operated (batteries are in the console) change them first. If that isn't the problem, you need to open up the bike and check the servo motor operation and the eddy mechanism. Many of the Icon bikes have lifetime warranty on the eddy mech. Check your manual for warranty coverage.
3/7/2019 4:33:03 AM • FreeMotion... • Answered on Mar 07, 2019
Cannot change resistance on my freemotion 335R bycicleThe resistance won"t change.
https://www.fitnessrepairparts.com/equipment/Select/20955/FreeMotion/335R-SFEX138121 motor part number-4taeoove4xnr5af20ezqxfvu-4-0.jpeg There is a support option at the website to help you determine if the motor needs to be replaced.
3/7/2019 1:32:34 AM • FreeMotion... • Answered on Mar 07, 2019
My freemotion treadmill displays controller error 08; what does this signify?
I have freemotion treadmill t12 ,and it says on the screen 0x00 and 0x23 ,anyone knows what are those errors?thanks in advance
2/25/2019 5:03:46 PM • FreeMotion... • Answered on Feb 25, 2019
FreeMotion XTC Recumbent Exercise Bike Logo
6 questions posted
Top FreeMotion Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • FreeMotion Exercise & Fitness
Most Popular Question
left pedal freemotion 270u exercise bike
  • Exercise & Fitness
