20 Most Recent
Astoria Divina SAE-2 Coffee Maker, Espresso Machine Questions & Answers
Jus got an astoria sae junior i got hot water steam but no water on brew head no boiler pressure is 0 all the time just change the pump need help
There could be a number of issues here. If the pump pressure reads 0 then that would suggest there is no power going to the pump. Does the machine hum when you press for a brew? If it does then the pump is receiving power.
If you have changed the pump recently have you reset the pump pressure manually on the pump head? This is done by adjusting the nut (12mm I think?) anti-clockwise to increase the pressure. Clockwise to reduce it.
Perhaps the pressure gauge is faulty?
No water to the brew head if the water pressure is fine and the pump is working indicates a blockage in the group head. You will need to strip down the valve and clear the filter which is a small hole under the large nut...
Make sure the water is turned off and the machine is cold and isolated before stripping out the valve.
