20 Most Recent
LG 1000W XM-Ready 5.1-Ch. Home Theater System with 5-Disc Upconvert DVD/CD Player Questions & Answers
LG 5 disc dvd changer. It has a CD stuck in the
Try unplugging it, and plugging it back in. Many times that will re-set the player, so you will be able to eject the CD/DVD
Sometimes there is a little pin-hole that can be used to manually eject the disc. Look for something like a small hole around where you insert the disc
Try to press and hold the power button for at least 20 seconds. This is suppose to reset the unit
If the unit is out of warranty, you might want to remove the top cover and manually remove the CD/DVD and force the tray open with a screwdriver. Sometimes a CD/DVD will not seat properly in the tray because the drawer was closed before the disc was properly put in.
9/2/2009 1:59:27 AM •
LG 1000W...
Answered
on Sep 02, 2009
Need manual for lg#lht764
you can hook up yor i pod unit directly into the back of the unit there is a special slot were it plugs into and you can use the remote to operate it once it is hooked up .you can veiw the functions from the tv in ipod mode or you can plug it in from the front lower left oped lid and plug and play
12/27/2008 5:26:36 AM •
LG 1000W...
Answered
on Dec 27, 2008
House hit by lightning
Try to plug it into a differen outlet. Also unplug it and open the case and look for a glass tube should be small and see if you have one in that case. If not then the cost to repair is high. You should get an estimate of how much the local repair should would charge you first. If it cost too much than what a new one would cost then don't repair it keep the speakers and get rid of the amp. But a new amp or another system if you want.
7/23/2008 9:11:18 PM •
LG 1000W...
Answered
on Jul 23, 2008
LG FB162 no sound when connected with Aux
Instead of aux (Blue Connector of PC Sound), try using head phone jack (Green Connector of PC Sound). It if is working fine, uninstall sound driver of your PC, restart PC and install sound driver again. Your problem will be fixed.
Audio not working on VCR side of LG LRY-517 DVD/VCR combo player
The back of the lry517 has 2 sets of audio outs and 1 set of audio ins. If you are using the component video outs, use the audio outs to the right of the component outs. If you are using AV1, it should be the audio to the left of the component outs.
The tape's audio may be very low, try turning up the tv volume? You could also try adjusting the tracking? Have you tried using the AV1 outputs? It would be Composite Video and stereo audio.
I have a “please wait” problem in my lg home theatre (model hb906sb) ??
The "please wait" problem in your LG home theatre (model HB906SB) is likely an issue with the system's firmware or software. Try unplugging the system from the power source for a few minutes, then plugging it back in and turning it on. If the issue persists, try performing a factory reset of the system. If none of these solutions work, contact LG customer support for further assistance.
LG DVD Receiver HT552TH is not switching from DVD to AUX or Band. What to do?
Here are some steps you can try to troubleshoot the issue with your LG DVD Receiver HT552TH:
- Make sure that the AUX or Band input is properly connected to the receiver.
- Try resetting the receiver to its default settings by unplugging it from the power source, waiting for a few minutes, and then plugging it back in.
- Check the input settings on the receiver and make sure that the correct input is selected for the AUX or Band.
- Try using a different remote to see if the issue is with the remote or the receiver.
- If the issue persists, it may be a hardware problem with the receiver, and you may need to contact LG customer support or take it to a professional repair service.
