20 Most Recent
LG SecurDisc 8x External Double-Layer DVD RW/CD-RW Super Multi Drive Questions & Answers
Toshiba netbook won't recognize LG GP08
If the drive is not self powered, it might not work because the USB port on the computer maybe does not have enough power to run the drive. Also, if the drive is USB 3.0, and the USB port on the computer is USB 2.0, it probably will not work. Good luck.
Driver download
where did you find the driver download for the lg gp08lu10? The official LG website doesn't have one!
Not able to view dvd
I am gonna assume that you mean a DVD movie here and it maybe that you do not have the codecs installed you'll need to download and install K-Lite Codec Pack. Make sure you uncheck the box to install Media Player Classic
Not read
When connected to the computer, make sure the drivers have been installed. Usually, this will occur soon as the unit is plugged in. If you are using USB to do this, and you plug it in to one port, and nothing happens, or the unit is unrepsonsive; try using a different USB port, or try using a different applicable cord, compatible with both the unit, and the computer. If this doesn't work, depending on how long ago you purchased the unit (brand new?) then I suggest taking it back to the place of purchase and seeing if you can either trade it, or find out if someone can further instruct you of it's installation process.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert, Phone Support, Live Chat @ Fixya.com
My MacBook doesn't recognize
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
I need the GP08LU10 XP driver
USB optical drives never require a driver when used in Windows XP. This
device is 100% Plug 'n Play in Windows XP providing it's a good drive
and plugged into a working USB port. The
OS
will detect and install a USB drive automatically without user
intervention within 4-7 seconds normally. When it does so, you will get
notification that the install was successful and that the drive is now
ready to use.
If it has never been prepped, ie: partitioned and formatted, then that
task will need to be performed using drive prep software usually
provided by the vendor/manufacturer or by using the built-in
partitioning and formatting feature that
Microsoft included with the OS.
I need LG GP08LU10 Driver for Mac please...
Unfortunately, LG does not offer drivers for their products for the Mac platform. You can use a program like Parallels to run Windows as a virtual computer on your Mac and install this optical drive under Windows.
I wish that I could be of more help.
How difficult is it to replace a CD-ROM drive in a MacBook Pro?
The fact that you realized replacement might be the best option and sought out advice tells me you are intelligent by nature. On a difficulty scale of 1-10 I would rate this in the 6-7 range. Someone like you would probably have very little trouble with this project. I have sent countless step by step instructions over the internet & through email but it seems like the best results always come from an in-depth tutorial, This way you can see EVERY step and even rewind if you're not sure about something. Powerbookmedic.com has a wonderful tutorial on the 17" MacBook Pro breakdown and optical drive (cd/dvd) removal. Just remember to always start with taking the battery out and be very careful about electrostatic shock. You should be fine on a hard surface but I don't recommend fabric/carpet surfaces once you open it up. Here is the link for your laptop. The videos will play in succession automatically. Good luck, you'll do just fine! If you run into trouble, just message back and I will be glad to walk you through it: http://www.everymac.com/systems/apple/macbook_pro/stats/macbook_pro_2.16_17.html
My cd is broken inside my lG cd rom what should
Hi
Thank you for your query
If you look at the side of the CD rom drive i.e. where the button is that you push to open and close the CD drive there will be a very small hole. If you open up a paper clip and poke the end into that hole you will notice the drive will pop out, once the drive has come out all you need to do is open and remove the broken CD
If this has been useful please leave positive feedback/vote/testimonial as this will help me greatly - Thank you again
My LG slim external drive worked a few days ago
I gives you a suggestion. Please scan your laptop. I guess virus corrupting your usb drives thats why its happend. every time u have got the same things. If you follow slowly slowly u have lost all of your external connectibity via USB or bluetooth also. if not found any virus and the same thing happend then i suggest you formet it and reinstalled your OS.
It can't read or burn any data on any empty disks
Some CD burners are either "+" or "-" or both "+ -".
That said you will have to check what type of burner you have. Example, you cannot stick a "+" blank cd into a "-" burner, and visa versa.
However, if your cd burner can read and burn both types, you should be okay.
Unknown
Try to put new cd or dvd that you know the other PC can read.May be the one your putting on has file that had been corrupt.
Try cleaning the Optical lens with Q tips dip in alcohol(isopropyl).
Open the device manager and Uninstall the CD/DVD drive from device manager.and let the windows force install it.
How to solve if the DVD player does not operate with windows 7 OS
No DVD or Blu Ray Drive support under Windows 7 64bit
Windows 7 64bit won't see any of my DVD or Blu Ray drives. I have tryed deleting the registry files and uninstalling but I still have a yellow cation in device manger. I have been doing this for weeks now with no help from LG I love windows 7 but like all PC 's it's just not right until the side is off and your under the hood. I guess that's why I have 4 Mac's now. Please help Microsoft. The current CD-Rom driver is from 2006
