20 Most Recent
Performance Teknique ICBM-772 Car Audio Amplifier Questions & Answers
My diagnostic light is on, md# icbm772
yes you have a internal fault of the amp. the circuit that puts it into
safe mode is bad and that is a very small chip on the board know as a
op amp. needs to be repaired.
I install wire from the battery to the amp ground
Power amps must be connected + battery wire to the amp +b terminal with a gauge 8 or bigger depending on the power rating, - ground to the car chassis as short as possible,connect cords from head unit to power amp with good groundings, and remember to connect the speakers and the remote trigger from head unit to turn the amp on.
Sub amp not working anymore
sounds like a typical case of poor conections causing the amp to fail... take the cover off of the amp. Inspect where the terminal blocks meet the circuit board. SOmetimes you can repair it sometimes its just too far fried..
