20 Most Recent Samsung WS32Z308P 32" TV Questions & Answers
TV Samsung WS-32Z308P (Slim-Fit CRT). Chassi S62A. TV keeps turning on and off in a 15 min cycle.
mine had 6 bad capasitors on which i replaced for 3.99 and been fine since.heres where i got my guide from.hope it helps... ELECTRONIC EQUIPMENT REPAIR CENTRE samsung smart tv fix YouTube
3/18/2016 5:48:49 PM • Samsung... • Answered on Mar 18, 2016
2answers
Samsung WS-32Z419D 32" TV wont turn on.
THIS IS A DESIGN FAULT IN THIS MODEL AND ALL WS32Z MODELS,SAMSUNG KNOW THAT AND WONT REPAIR OR RECALL THE PRODUCT, SOMEONE SHOULD CONTACT THE FAIR TRADE OFFICE, THGOUSANDS ARE AFFECTED.
THE PROBLEM IN THE loptx THE TRANSISTOR J6920A AND THE CAP NEED REPLACEMENT AND IS AN EXPENSIVE JOB.REPORT FAULT TO SAMSUNG THEY SHOULD RECALL THESE MODELS AND REPAIR THEM OR REPLACE,AS THERE IS NO GUARANTEE THAT AFTER REPAIR THE SAME PROBLEM WONT REOCCURE AGAIN.
8/12/2014 10:34:03 AM • Samsung... • Answered on Aug 12, 2014
2answers
My Samsung Plano TV (Model is CS-20M16ML)
To get a full picture, you have to set the aspect ratio of the display. If you haven't a remote control, you can't do it. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchased a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/ If you see these sites by "MOSAIC" or "Magazine" view will make surf easier. Universal remote controls are available at most of the electronic spare part selling shops or online by Ebay or Alibaba.com. Keep this in mind, that some universal remote control won't allow you to change the aspect ratio of the picture. So, it will be best to buy its genuine remote control, from the authorized service centre for Sanyo.
5/21/2014 10:20:50 AM • Samsung... • Answered on May 21, 2014
Ws 32z308phow can i get spar parts for this modelspecial in egypt
all spare are common expect processor & chroma ic what spare you need
4/29/2014 9:52:09 AM • Samsung... • Answered on Apr 29, 2014
How can I get spare parts for samsung tv model ws32z30 in Egypt
its power supply fault power supply spares are normal available electronics shop or buy from ebay also. check fuse,diode,transistor & opto cupler
4/29/2014 9:34:37 AM • Samsung... • Answered on Apr 29, 2014
2answers
Sky remote tune to samsung
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
5/17/2013 3:17:45 PM • Samsung... • Answered on May 17, 2013
3answers
Samsung plano tv
The problem that is happening is due to the shutdown circuit activating, which is an indication of excessive current flow. This may indicate a problem in the High Voltage section or in the power supply feed from the HV section. In any case this problem is best dealt with by a trained professional. I would suggest that you take the TV to a qualified TV repair person and have them check it out.
I hope this helps
Thank you,
Shuttle83
7/26/2012 5:42:18 AM • Samsung... • Answered on Jul 26, 2012
When I put on my Samsung Plano TV (Model is CS-20M16ML) the picture display after sometime becomes problematic. The blankness appears at the bottom of the screen and then gradually goes up and up thus
Vertical output IC has the fault. Try this site named "Electro-help". You might get details from here. Type this name in google search box and click enter.
5/2/2012 2:11:35 AM • Samsung... • Answered on May 02, 2012
Tv will not turn on
These models are subject to burn out, contact Samsung and they can give you further information or ever swap your model for another.
5/25/2011 6:29:31 AM • Samsung... • Answered on May 25, 2011
The stanby light goes
Hello
If the power indicator is blinking on the front of the VIERA, turn off the TV and unplug all HDMI cables that are connected to the TV. Then unplug the power cable from the current power source. Try a different electrical outlet. Remove the power cable from the rear of the TV and plug it back it in (the power cable tab is inserted correctly when you hear a click).
4/23/2011 4:41:09 PM • Samsung... • Answered on Apr 23, 2011
0answers
0answers
HOW TO GET HDTV FOR SAMSUNG WS32Z308P
You will need an HD receiver (Freeview HD, Freesat HD or Sky). For Freeview HD you'll need to check whether it's being broadcast in your area yet. Check the freeview site
5/1/2010 9:11:43 AM • Samsung... • Answered on May 01, 2010
2answers
Red colour trouble SAMSUNG CRT
Problem with RGB circuit.
Check the red signal drive electroncis.
4/8/2010 11:35:58 AM • Samsung... • Answered on Apr 08, 2010
My samsung WS32Z306V WONT TURN ON AND JUST HAS A
Hi, Sorry this is not a fix but i wanted to say that i have the same problem on my tv which is the same model as yours.
At start tv would show faint parallel diagonal lines until some day it stopped working. Everytime i try to turn it on it doesnt! and makes a ticking sound from the back of the tv. Did you fix yours btw?
3/17/2010 1:39:59 PM • Samsung... • Answered on Mar 17, 2010
Samsung WS32Z308P 32" TV Logo
46 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
  • Samsung Televison & Video
Most Popular Question
samsung plano tv model cs 20m16ml
  • Televison & Video
