20 Most Recent
GE 25865 Cordless Phone Questions & Answers
New Voice mail flashing on phone but no new messages
Have someone call you and leave you a message. then listen to the message and that might reset it.If that dont work call the manufacturer and they will walk you through it and should not charge you for it.
2/14/2009 10:12:47 PM •
GE 25865...
Answered
on Feb 14, 2009
I only seem to get Caller I.D.records for calls to line 1
Go into the menu option under set up and go step by step and it will bring you to caller id option. There , you should be able to turn on the caller id for both lines. I just went through this with my parents phones. after you do it you wont believe how easy it was.
1/4/2009 1:39:11 AM •
GE 25865...
Answered
on Jan 04, 2009
Out of range message
We've been having this problem for a while. I used to think the hand-held needed charging. But just today I tried pushing all the plugs firmly into the back of the base. It turned out that the main power pin, on the back right, had been pried loose which must be a problem with being gradually turned in its socket and rotating against a cuff which wedges it loose. This seems to easy and obvious a fix but both hand helds have stopped reporting out of range -after they reajusted them selves to the base.
1/1/2009 2:34:08 AM •
GE 25865...
Answered
on Jan 01, 2009
No dial tone at all!
I assume you put the battery in and charged it for 12 hrs. If everything is plugged in correctly then it's time to return the phone as it is defective. GE does not have a very good rep with phones.
10/29/2007 6:36:12 PM •
GE 25865...
Answered
on Oct 29, 2007
I have a GE model #29893GE1-B it is connected and plugged in, but no dial tone
Remove all the phones on the system. Remove all the handset batteries. Plug in one old style corded phone to the main phone jack, it is normally the one closest to the front door. Do you have dial tone? If not, it is your Telco. If you have a dial tone, plug all the other phones in testing for a dial tone as you go.
Why is my GE washer leaking water from the right front corner?
A leak coming from the front of a front-load washer is often caused by a damaged or dirty door seal. If the door seal is cracked or loose, it will need to be replaced in order to restore a watertight seal. Always ensure all clothes pockets are empty prior to washing, as objects left in pockets can damage the door seal.
Trying to find replacement phone battery for GE model 2-9421A phone set s/n 80052268.
If you mean the long-life lithium backup battery for the corded 2-line GE 2-9421 (A indicating the sales region), that is a 3V Lithium battery. The part number 5-1923 appears to be a common CR2032 coin cell battery. These are used as backup batteries for Eraseable Programmable ROM on many devices, including computers.. One source is https://www.batteriesdirect.com/product/details/button-cell-batteries/ge/5-1923 . Any CR2032 from a reputable manufacturer will work.
I hope this helps.
