20 Most Recent Motorola Mobility ROKR E1 Cellular Phone Questions & Answers
0answers
0answers
INQUIRY
Be the first to answer 3/3/2017 10:24:03 AM • Motorola... • Posted on Mar 03, 2017Be the first to answer
Need "ROKR E1 unlock code"
Get the unlocking code for your mobile from Superunlockcodes.com .This is the online service provider which offer the service for your mobile.You can use this and unlock your mobile easily.
4/23/2012 9:51:45 PM • Motorola... • Answered on Apr 23, 2012
Bar password e1 rokr
You will need to take the phone to a mobile phone repair shop to get it unlocked and reset to factory.
3/10/2012 12:15:54 AM • Motorola... • Answered on Mar 10, 2012
0answers
My motorola e1 fall in
if your phone is wet,do not try to switch it on before you dry the battery and phone separately,they need to dry on natural air,that means that you need to wait for availe.back cover need to be open,ofcourse.
3/20/2011 7:50:15 PM • Motorola... • Answered on Mar 20, 2011
I have a motorla rokr
2/21/2011 2:07:25 PM • Motorola... • Answered on Feb 21, 2011
After I transferred the photos
Welcome to Fixya
Looks like the firmware hangs up or LCD backlight problem. Try to drain the eloctrastatic energy of the board first. Take out the battery then press and hold the power button for 15 secs. Put back the battery then turn on the phone. If still getting no display even the unit is owering on. The problem is the LCD backlight.
Thank you for using Fixya! If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
2/21/2011 3:24:58 AM • Motorola... • Answered on Feb 21, 2011
My problem is in i tunes i dont have song in i
You will need to download the itunes software program from the site below:
http://www.apple.com/itunes/download/
Now down load the program and install it in your set , then convert all the files into the itunes .
1/6/2011 6:11:53 AM • Motorola... • Answered on Jan 06, 2011
0answers
I want to unlock my motorola ROKR phone, how do i
As you have not specified which code you need i am hereby giving how to get all of the codes:
NETWORK UNLOCK CODE:
You can unlock it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If your mobile is not an CDMA mobile , you can get the network unlock code(NUC) by just contacting the current network provider customer caredepartment.It is free of cost.
Therestrictioncodecan be got from your old service provider..This restriction code iskeptto prevent someone who stole themobile from using it withanotherprovider...
They will have a security check done with your date of birth etc..to verify whether you are the exact owner of the phone..
After that they will provide you the restriction code to unlock it and use it with another service provider..
It is all free of cost donot pay anyone for this seeing some advertisement over internet . That is all fake ads.
The above proceudre works and you can verify that by seeing the rating of an happy customer here..
http://www.fixya.com/support/t4035818-need_unlock_nokia5130c_2_use
PUK CODE:
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider cangive it nobody else in this world nor any software.
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
7/12/2010 7:38:07 AM • Motorola... • Answered on Jul 12, 2010
Motorola rokr e1..all of keypads & joystick
open up and clear for moisture/ sweat on the pads. use a hot air blower (Hair Heater) to warm up the board and dry. Good Luck
6/28/2010 5:59:30 AM • Motorola... • Answered on Jun 28, 2010
T_T i killed my phone (ROKR E1). . and now it
go to http://www.modmymobile.com, download p2k tools, p2k driver, and search firmware for your rokr e1
6/15/2010 6:50:32 PM • Motorola... • Answered on Jun 15, 2010
My Moto rokr freezes on start up when the silver "M" appears
try to remove a memory card or your phone is need to reprogram.go to http://www.modmymobile.com to download tools and firmware for your rokr e1
6/15/2010 6:42:04 PM • Motorola... • Answered on Jun 15, 2010
Motorola rokr model cell phone - I can't figure
go to message>new message>new short message>press menu>click entry setup>and change primary setup to tap extended
6/15/2010 6:31:03 PM • Motorola... • Answered on Jun 15, 2010
When texting message,entering name or txting
your handheld is need to reprogram
6/10/2010 7:34:50 PM • Motorola... • Answered on Jun 10, 2010
Code to reset my motorola rokr E1
enter 000000 for reset code
4/10/2010 7:39:18 PM • Motorola... • Answered on Apr 10, 2010
6answers
Motorola ROKR e1 keypad problem
It's the problem with the keypad board, the hardware problem not software, clean the connector carefully and replace the keypad board with the new one. This will solve the problem. Regards.
1/4/2010 11:27:02 PM • Motorola... • Answered on Jan 04, 2010
0answers
Canot program
Be the first to answer 1/2/2010 5:52:38 PM • Motorola... • Posted on Jan 02, 2010Be the first to answer
Motorola Mobility ROKR E1 Cellular Phone Logo
51 questions posted
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
 Mikey
Mikey
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Cell Phones
Most Popular Question
moto rokr freezes start up when silver
  • Cell Phones
