20 Most Recent Motorola Mobility i355 Cellular Phone Questions & Answers
Perform a hard reset on Motorola C139 from Tracfone
Master Reset
  1. From the standby screen, press the Menu key.
  2. Scroll to and select Settings.
  3. Scroll to and select Other Settings.
  4. Scroll to and select Initial Setup.
  5. Scroll to and select Master Reset.
  6. Enter the Security Code, press OK. NOTE: The default security code is 1234.
But... it doesnt sound like this will help your problem as i have a feeling that you have a logic board issue and even if you get it to work its going to do it again... and again... and your not the only one.... is quite common fault Do Not Choose Motorala would be a good recomendation for your next phone! maybe LG or Huawei...
5/8/2017 2:14:51 AM • Motorola... • Answered on May 08, 2017
I have i355 motorola phone bought it from my freind from canada but in my location its not working, so please tell me how will it work in my country
May be the mobile is locked with a Canadian Network.Try inserting other sim cards and even then it is not working then definitely your mobile is locked.You need to enter the unique unlock(subsidy) code for the mobile to break from the restriction.You can get the unlock code for your Motorola i355 from http://www.theunlockarena.com/motorola-i355/rs16wp9/ and remove the network lock easily by specifying the country and network to which the mobile is locked to.
12/21/2014 8:01:33 AM • Motorola... • Answered on Dec 21, 2014
Where can i get free sim unlock codes for motorolla i355
Hi! In this case the best will be to get in touch with your carrier to verify if it's possible for them to share the code with you or if there is any requirement they have for you ask for it. Regards, Gaby R. Motorola Support.
9/17/2014 4:12:07 PM • Motorola... • Answered on Sep 17, 2014
I need to get an unlock code for a motorola i335
try going to unlockbase.com
2/19/2010 9:17:57 PM • Motorola... • Answered on Feb 19, 2010
Finding menu
contact your cellular provider. the process is device and service provider specific. Its a chain of events in those old 1X phones that need to be keyed in sequence. contact them, and they will be able to walk you through each individual step that needs to be taken to "Master reset" or "Re-Program" this phone :)
Hope that Helped! -Jordon
9/2/2009 10:37:09 PM • Motorola... • Answered on Sep 02, 2009
0answers
Nextel I355
not able to cherp out
4/23/2009 8:57:24 PM • Motorola... • Answered on Apr 23, 2009
Ptt button not working
rjapilan,
That job will require micro soldering and a replacement switch. I recommend these guys to do the work. Cell Phone Technicians
Sorry I could not provide a DIY solution but this task is not home friendly.
Good Luck
ERIC the PHONE GUY
12/22/2008 3:35:29 AM • Motorola... • Answered on Dec 22, 2008
How to put text (name) on home screen??
the easy way, go to styles in the home menu, press ok, go to the selected item, press menu, edit, go to name and press ok, then put you name, then ok, and then press ready in low right corner.
thats all
5/22/2008 4:07:24 PM • Motorola... • Answered on May 22, 2008
tip
Sim Network Unlock Pin Motorola
How to enter my Unlock Code on Motorola ?
Model : All Motorola 1 - Switch ON your phone with a not allowed SIM Card, 2 - Phone show "Enter Special Code", 3 - You can now enter the Unlock Code we send to you. WARNING : If one of theses messages appear : - "Contact Service Provider" - "Tampert Alter" - "Wait before enter special Code" - "Contact Service' It's because you or somebody allready enter too many wrong codes, you just have to let phone ON on theses errors messages and after 40 min to 2 hours maximum the message "Enter Code Special" will appear again !
https://www.unlockbase.com/faq/en/Q_47.html
0answers
Mp3 download
Be the first to answer 4/11/2017 8:51:03 PM • Motorola... • Posted on Apr 11, 2017Be the first to answer
2answers
Kyocera DIGNO Dual WX04K. HOW TO RESET KYOCERA WX04K DUAL DIGNO please?
How to hard reset KYOCERA DIGNO WX04K WILLCOM
GSM Hosting https://forum.gsmhosting.com > vbb > how-hard-reset... Feb 24, 2016 - Ihave solution turn off mobile than holde both volume keys and connect usb i will install adb drivers and than install kingoroot in pc and ... Missing: DUAL ‎' Show results with: DUAL
How To Do A Hard Reset On Kyocera DIGNO Dual WX04K
Tweakdroid https://tweakdroid.com > hard-reset > kyocera-digno-d... Nov 28, 2021 - To start, go to the Settings menu of your Kyocera DIGNO Dual WX04K; Find the factory data reset option. · Click on Erase all data. ; Turn off the ... ..
4/25/2024 9:08:18 PM • Cell Phones • Answered 6 hours ago
I had a paper jam in this model: DM72C and I cleaned all the paper out but it won't start shredding again even though all the power lights are on and ready. What am I missing?
You were asked questions? I have been campaigning for this for 3 months. I told them you need a pop-up All questions need 'make model (what it is)' as first 3 words. You are missing the maker, but you do mention 'shredding'. Then I also said 'There are 40,000 categories to choose from'. You chose 'Cell Phones'. and it's not a 'memo', it's a question. :>) So, first of all, disconnect it from the mains for 30 minutes. If you jammed it, you were working it hard, and when it jams, heat builds up in the motor and trips the thermal protection device. They have a thermal cut out, some have a thermal fuse what need physically replacing, but most reset when they cool. Does it work in reverse? A jam can sometimes damage the switch in the throat of the shredder, some are a mechanical switch, some are an infra-red sensor. https://www.google.com/search?q=DM72C ..
4/24/2024 12:12:23 AM • Cell Phones • Answered 2 days ago
4answers
HOW TO GET A PIN CODE IN RAN ONLINE PH
how to retrieve my pin code in ran online
4/23/2024 5:38:00 AM • Cell Phones • Answered 2 days ago
2answers
What is the difference between CEH V8 and CEH V9?
The difference between EC-Council's Certified Ethical Hacker v8 and the new Certified Ethical Hacker v9 is not the exam format, but the content itself. People seem to assume that since EC-Council updated the certification, the exam must be brand new. This isn't the case. In order to obtain the new CEH v9 certification, you do not need to study for and pass a brand new exam with new objectives and format. The test has the same format, is identical in size, and has the same amount of questions. There are only two things that changed. CEH V9 EXAM FORMAT AND BREAKDOWN The aforementioned v9 exam follows the same format and percentage breakdown of questions as v8. For example, the section on security will still take up 25% of the exam, while the section on tools, systems and programs will take up 32% of the exam. The full breakdown of the exam is visible on our . The Exam Details are as follows:125 questionsTo pass you need a score of 70%Maximum of a 4 hour durationMultiple choice formatHOW TO PASS YOUR CEH EXAM If you are studying v8 exam materials, you are not automatically going to fail the v9 exam. The test is updated, not revamped. This means there might be a handful of questions you may not necessarily have studied in depth for, but if you studied at all, you will have some familiarity with the new questions. The new questions are not on brand new material, they are more in-depth questions on topics that have become more relevant in the cyber security world over the last eighteen months. So you can still pass v9 studying v8 material.Should I still take CEH v8 Exam? However, if you study v8 materials you can still take the v8 exam. EC-Council has not retired the exam yet. So if you are not comfortable with the idea of taking an exam that you may not know 10-15 "new" questions, then don't. The only problem with this is that once the v8 certification does retire you will eventually need to take v9. Why prolong the inevitable then?Will I need to take the CEH v9 exam? If yes, then when? The test is updated on a rolling basis. This means that occasionally EC-Council adds new questions to the exam without updating the entire certification. The fact that v9 is now available means that there are new and updated CEHv9 study materials with a new focal point to deal with the always progressing world of IT.THE DIFFERENCE BETWEEN CEH V8 AND V9 With the update to the courseware, the exam covers certain questions differently. These questions focus on topics that are becoming more prevalent in the world of cyber security and IT. The key differences are:V9 focuses on cloud computing more than v8 did and dives into best security practices for dealing with cloud computing attacks.V9 covers mobile security and tablet computers and you must understand how to perform hacking techniques on these devices.v9 addresses new vulnerabilities in cyber security such as, Heartbleed, Shellshock, and POODLE. CEH v9 vs v8 What New on the Certification Exam TechRoots
4/22/2024 6:43:13 AM • Cell Phones • Answered 3 days ago
I'd like to update my stereo in my Citreon C3 (2007) to a double din header unit.
Let's explore your options: Double DIN Stereo Upgrade Kits: There are aftermarket double DIN stereo upgrade kits available specifically for Citroen C3 (2010-2016) and Citroen DS3 (2010-2019) models. These kits include everything you need for a seamless installation, including a fascia kit, plastic brackets, screws, blanking buttons, steering wheel control interface, antenna adapter, USB and AUX retention leads, and a universal patch lead. The installation process involves removing the original single DIN radio, fitting the new plastic frame and fascia around the double DIN radio, and connecting the wiring harness and other components. These kits are designed to retain steering wheel audio controls and other features. Keep in mind that dashboard modifications are required, so professional installation is recommended. Connects2 Adapters: If you choose an aftermarket stereo that isn't specifically designed for your Citroen C3, you can use a Connects2-style adapter to convert a compatible aftermarket stereo to control the screen above the radio (date/time, etc.) 3. This way, you can still access essential information. For example, a Double DIN Android Auto-compatible stereo like the JVC KW-M560BT could fit in the space after removing the cubby and factory radio. Some C3 models have a dash-mounted CD autochanger or other features that need careful handling during the upgrade. Citroen C3 2009 Aftermarket radio upgrade - Double DIN (citroenc3owners.com) Professional Installation: Consult with a car audio installer or technician to choose the best solution for your specific Citroen C3 model. Regardless of the approach you take, professional installation is highly recommended.
4/20/2024 10:12:16 PM • Cell Phones • Answered on Apr 20, 2024
Motorola Mobility i355 Cellular Phone Logo
18 questions posted
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Cell Phones
Most Popular Question
get free sim unlock codes motorolla i355
  • Cell Phones
