20 Most Recent
Consew 199R-1A Sewing Machine Questions & Answers
Thread a consew 199r-3a
you can google your make and model sewing machine with the word "manual" and you can get one.
HI problem with Consew 199R-1A. Machine locked
Good day!
that problem is usually happen when your machine have clog or no lubrication please try to use oil to lubricate your machine at all moving parts inside.
Thank you and good luck.
TIMING HOOK
Hi the best advise i will give to you concerning the proper settings of the machine is to send an email to
[email protected] to request for the settings or you can get it from this page yourself... http://consew.marginspluslive.com/images/products/specsheet2007/199rbseries-WEB.PDF Take care
Cannot get tension balance correct
Try this. reomove thread and bobbin from machine.. Set thread tension to the middle number. Rethread machine carefully making sure the thread is thru the tension wheel. Replace bobbin making sure that thread is thru it's tensioner.
Rule of thumb. Loops on the bottom, problem is on the top. Loops on the top, problem is with the bobbin.
What are the oiling recommendations for Consew 199R-1A?
Keith, onthe head of the machine there should be about 5 spots to oil.
1) near wheel on top of machine
2)near the top left hand side
3)) in the middle of those 2
4) open bobbin case , remove bobbin and oil around the rim of where the bobbin sits
5) about 1/2 way between needle and base of machine.
You should blow out machine with canned air and then oil once a month.
