YELLWWORSE Bluetooth Headphones V4.1 Wireless Sports Stereo Earbuds with Mic, Noise Cancelling, IPX4 Sweatproof, 8 Hrs Playtime
More Comfortable, Safe and Secure Fit: Yellwwors sport Bluetooth features flexible ear hooks following the contours of your ears for a custom secure fit to prevent earphone from fall off accident.With Ergonomic design and light in weight, you will experience unprecedented comfortable sensation when you are running, jogging or exercising.It is the best for GYM
- More Professional Technology and Highest Standard Parameters: With Advanced Bluetooth v4.1, CVC 6.0 technology and apt-X tech, the headphone ensure bring you superior sound and amazing volume,it offers perfect enjoyment of music with powerful bass, super 3D stereo sound.
- More Convenient : Support voice-activated answer calls, voice prompts, battery indicator of your phone(only iphone and MI), Three-way calling function, Connect two phones at the same time
- Universal Compatibility: With V4.1 tech, Yellwwors headphones can work seamless with your favorite bluetooth devices, including iPhone, iPad, iPod Touch, Android Smartphones,tablets,Windows laptops, desktops, chrome Books,Bluetooth-enabled music players and more
- ULTRA-LONG PLAYTIME and EASY TO USE: Yellwwors Bluetooth headphones can deliver up to 8 hours of play time on a full charge.The design is more simple and practical
The wiring in the cable got loose so now it no longer makes a proper contact on the capsule in the rear. It can be fixed, it's a very simple job - all you need to do is to open the headphone and resolder the wire to the capsule.But finding a shop that would do that for less than the price for a new pair of headphones will be close to impossible in the western world.
apple's love is too deep. crumple some tinfoil - aluminum foil - and drop it in the jack receptacle, then insert jack - worked perfectly for me - after a long frustrating morning surfing for solution.
Could you please add a picture of the components which are heating up crazily? There is a good chance these are voltage rectifying chips. Those will boost the voltage up or buck the voltage down to a specific number.
Please add the picture so I can take a look at which components they are.
If they are the Apple ear bud clones, there is a technique to get them paired and both working. You get the left to work, or you get the right to work!!
Tell your phone to Bluetooth Search.
Press the On button for one earbud.
Press the On button on the other earbud and then double press the button on that one.
Go to the phone. At the bottom of the Bluetooth list you will see two numerical entries that say paired. Ignore those. In the top list of Bluetooth items you have used before, you will see one that is the Friendly Name for your earbuds (mine says i12-TWS). Press that once and it will change to connected. Then both will be connected.
Hi there PatAccording to the user manual for the ipod nano 5th generation you can add audiobooks. These directions are directly from the manualIn itunes, select ipod nano in the devices list and click on the music tabThen select Sync Music, and then do one of the following:(a) Select "Entire music library"(b) Select "Selected playlists, artists, and genres," and then select Audiobooks (below Playlists).Click Apply.The update begins automatically.Hope this helps.
MOV is a common multimedia format often used for saving movies and other video
files; uses a proprietary compression algorithm developed by Apple
Computer; compatible with both Macintosh and Windows platforms.To play a MOV file, use this playerhttp://movplayer.net/
Press the Menu button on your VIZIO remote. Use the arrow keys to highlight 'Audio' or 'Audio Settings' and press the 'OK' key on the remote. Make sure it says 'On' next to the TV Speakers setting. If it states off, press okay to choose 'ON'.https://downloadnox.onl/ https://vidmate.vet/ https://vlc.onl/
First plug your i-pod 1st generation into my usb port on your computer.Then download and install Sharepod. when the it appears right click the selected song and delete it, in the main menu
Hi Vicki Greenwood, so your Yamaha tells you, check that your speaker cables are not damaged or improperly connected
On the other hand, it controls the level of signal that is input from the Apple TV, it may be overmodulating
Take the tests and comment
Regards Franco Dosil
Hola Vicki Greenwood, por lo que te indica tu Yamaha, comprueba que los cables de tus bafles no esten da?ados o mal conectados
Por otro lado, controla el nivel de se?al que le ingresa desde el Apple TV, puede estar sobremodulando
Haz las pruebas y comenta
Saludos Franco Dosil
https://usa.yamaha.com/files/download/other_assets/2/319822/01_om_htr-5940.pdf
There are two ways to delete music from your iPod. The first is to delete songs in your iTunes library and have iTunes sync your library to your iPod automatically when you plug your iPod into the computer. The second is to manually delete music by resetting the options to a manual setting and deleting music directly from your iPod without affecting the songs in your iTunes library. Follow these steps to delete music from your iPod. Open up iTunes by double clicking on the "iTunes" icon. Go to "Library" on the far left side of the screen. Click "Music" from this list, which will bring up all your music on the main part of the screen. Choose a song you would like to delete from the list and right click on it. Click "Delete" from the drop-down menu that appears to delete your song. Go to the bottom of the left column on the screen to "Playlists." Click on one of your playlists to bring up the list of songs in the list. From there you can delete a song on the list. Connect your iPod to your computer. The iTunes program will automatically sync your iPod to whatever you have changed in your iTunes library as long as it is set to the default settings. Manually Delete Music Connect your iPod to your computer. Open up iTunes. Choose the third option in the "Options" menu called "Manually manage music" by checking the box next to it. It will ask you if you are sure you want to manually manage music on your iPod. Click "OK." Go to "Devices" on the far left column on your screen. You will see your iPod's name directly underneath that with an arrow pointing to the right. Click on the arrow, which will cause it to rotate until it is pointing downward and a drop-down menu will appear with all your songs listed. Click on a category or playlist, which will bring up all the songs in the list in the main section of the screen. Choose on a song listed that you would like to delete and right click on it, then click "Delete" from the drop-down menu that appears to delete your song.
I think you can try Leawo Blu-ray Ripper, it is an all-inclusive tool for handling both Blu-ray and DVD discs. The ability to decrypt Blu-ray disc with MKB level ranged from 0 - 21 and with AACS and BD+ protection has made it the strongest ever to rip Blu-ray videos. Here is the full guide to tell you how to rip blu-ray or DVD to iPod video.
Unfortunately, lightning may have damaged your equipment beyond simple fixes. Most likely the sensitive circuits inside are blown, and you may need to replace them all.
