20 Most Recent GE Security DVMRe-16CT-600 16-CHANNEL Color Triplex Multiplexer-Recorder with 600-GB Hard Drive, Ethernet Questions & Answers
Default password
If memory serves me correct, most of the GE/Truvision etc. DVRs have to be sent back in for the password to be defaulted. I may be incorrect on this, will double check.
7/21/2018 1:55:57 PM • GE Security... • Answered on Jul 21, 2018
0answers
Elec dvr
Be the first to answer 3/10/2014 3:45:43 AM • GE Security... • Posted on Mar 10, 2014Be the first to answer
3answers
Help me!
I have strongly recommended that change your power supply with the same specification voltage and amp. I have installed so many GE DVR's most of DVR's restart when the power supply is not working properly or HDD have bad sectors. I also recommend use the scan disk on you HDD for proper checking of your HDD.
FROM
AI
2/10/2014 6:04:08 AM • GE Security... • Answered on Feb 10, 2014
0answers
2answers
I'M TRYING TO REPLACE HARD
Hi I do NOT think that this adapter will/would work, you see even though one may think it should, this unit actually requires a native drive, not an adapter, you need to remove the adapter and use a drive that direct connects then it will work. It is really that simple.
Usually one Formats, on a PC via a USB dongle etc, and gets the HDD all ready to install, then, one plugs it into the interface and power, and then the unit should "See" the new HDD and perform it's "Housekeeping duties" on it, and make it available for use. Alternatively, one can simply hook it up, direct, and then the device should again "See" it, and the device will/should then Format it itself, and make it ready to use, the reason we may do in on a PC, is sometimes this is where there may be problems, formatting etc, that will not happen if done on a PC first. If done on a PC, ensure you format the correct format, usually FAT32, but not always.
There are a few tutorials online, perhaps it may pay to have a look for one, and follow it to the letter, to get the best result.
6/23/2011 9:25:19 PM • GE Security... • Answered on Jun 23, 2011
What is password of dvr ge security problem:
3123
3477
6321
1111
7/31/2010 7:41:17 PM • GE Security... • Answered on Jul 31, 2010
2answers
Dvmre triplex
I would switch monitors and see if the problem still exists. Sounds like the monitor not the Dvmre.
6/11/2010 9:34:19 PM • GE Security... • Answered on Jun 11, 2010
0answers
How to change view on cameras
pressing the corresponding number button will bring that camera up full screen. the buttons surrounding the A - B output source button will change the way your cameras are multiplexed on your monitor. you can also change which picture displays in each box including multiples of 1 camera by pressing the enter button on lower right and using the jog wheels to move (inside wheel controls up and down- outside wheel does left and right) the highlighted number where you want to put the cameras image. press the associated camera number you want there and it appears. press enter to lock the screen.
8/24/2009 11:51:46 PM • GE Security... • Answered on Aug 24, 2009
Need to get video off dvr
From the user manual page 71:
5.2 Quick Archive to CD
Archive to CD on the Disk Analysis Screen by selecting the time and date and pressing the record
button. The QuickWave Setup must be set to ON from the Archive Setup → Quick Wave Setup menu
(see section 3.15). The Archive Incident menu should appear.
1. Use the Jog to modify the time parameters and use the
Shuttle to move between the Start and Stop fields.
2. Press the Record button on the front panel when satisfied.
3. The CD Writer will open the CD tray when completed.
The video may now be viewed on any PC equipped with a CD-ROM.
You can download the complete user manual here:
http://www.gesecurity.com/portal/site/GESecurity/menuitem.f76d98ccce4cabed5efa421766030730?selectedID=1965&seriesyn=true
12/28/2008 4:18:56 AM • GE Security... • Answered on Dec 28, 2008
Intaller code
The factory default code to reset the system is 8111, however this will reset all program functions back to the factory settings, with the exception of the time and date. The default Operator code to use the system is enter, enter, enter, enter. This should allow you to operate the system.
8/26/2008 2:00:06 PM • GE Security... • Answered on Aug 26, 2008
Installer code
Hit menu button, top right of jog, installer code is 3477, then use jog and dial to change settings. These must be done locally!
8/26/2008 12:45:58 PM • GE Security... • Answered on Aug 26, 2008
No Audio
Check in the settings and make sure it is selected to be on.
8/24/2008 4:03:36 AM • GE Security... • Answered on Aug 24, 2008
Operating disk
Go to this site and download WaveReader software.
http://www.gesecurity.com/portal/site/GESecurity/menuitem.11620ebca5cc0a06574efe10140041ca/?vgnextoid=4f9fe4997e789110VgnVCM100000592d7003RCRD
8/5/2008 5:53:33 PM • GE Security... • Answered on Aug 05, 2008
GE Security DVMRe-16CT-600 16-CHANNEL Color Triplex Multiplexer-Recorder with 600-GB Hard Drive, Ethernet Logo
27 questions posted
Top GE Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Home Security Expert? Answer questions, earn points and help others
View Most Popular
GE Home Security
  • GE Home Security
Most Popular Question
default password
  • Home Security
