20 Most Recent Korg (KCDRW1X8X) CD-RW Burner Questions & Answers
I have a korg triton
you gotta get a scsi to scsi cable (64 pin). as well as a scsi card for youre computer,once you get those follow the manual and itll show you.
3/19/2013 7:19:13 AM • Korg (KCDRW1X8X)... • Answered on Mar 19, 2013
2answers
The hard drive in my machine is nearly full, so i
Right click on the D32XD ICON and check its properties ..It will indicate how much it is full or how much its empty
10/28/2010 10:59:43 AM • Korg (KCDRW1X8X)... • Answered on Oct 28, 2010
When cdrw is inserted into
try using a different type/brand of cdrw you may have a bad batch of cheap cdrw as for the freezing if this does not fix the problem try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
9/3/2010 4:01:26 PM • Korg (KCDRW1X8X)... • Answered on Sep 03, 2010
2answers
Korg Triton Studio, CD Burner Locks up keyboard on
I had this same problem. When you turn on your keyboard you should see the software version. I bet yours is 2.0.1 or earlier. These versions will lock up your CD drive.
You need to upgrade to 2.0.2
8/18/2010 6:19:44 PM • Korg (KCDRW1X8X)... • Answered on Aug 18, 2010
Where can I buy the CDRW for Triton Studio?
I heard you can buy them directly from Korg. I bought mine off ebay new.
10/2/2009 2:29:15 AM • Korg (KCDRW1X8X)... • Answered on Oct 02, 2009
Hi KORG i4 no sound inbuilt speakers
Do you get any sound from the internal speakers? If not go to Global>Audio Outputs>Metro S/PDIF tab>Check on the Speakers on/off option
3/22/2024 7:43:53 PM • Korg Computers &... • Answered on Mar 22, 2024
I have a Korg M50 and the sound immediately cuts when I press a key
Refer to page 103 of manual https://c3.zzounds.com/media/M50_OM_E3-5fa9fe2815369e7f207af92e639b141d.pdf It may help you.
9/15/2023 7:34:30 PM • Korg Computers &... • Answered on Sep 15, 2023
My Korg D3200 cd player won't open
6/8/2023 7:33:27 AM • Korg Computers &... • Answered on Jun 08, 2023
When replaceing battery in 01R/W when module should be connected to power again - before or after battery replacment ?
When replacing the battery on a 1R/w module, it is generally recommended to disconnect the module from power before replacing the battery. This is to prevent any potential damage or issues that may occur from power being applied to the module during the battery replacement process.
Once the battery has been replaced, it is recommended to reconnect the module to power and perform a power-on self-test (POST) to ensure that the module is functioning properly and that the battery replacement was successful.
It is also important to check the manufacturer's instructions for the specific 1R/w module you are working with, as there may be additional steps or precautions that need to be taken. It's important to follow the manufacturer's instructions in order to avoid any damage to the equipment or to ensure proper operation of the module.
1/25/2023 2:26:46 PM • Korg Computers &... • Answered on Jan 25, 2023
Korg EK-50 Not working after downgrading.
I this a USA keyboard, no country told. will only answer for USAredux1: simple.1: ask a shop to fix it.2: ask the maker for help KORG.https://www.korg.com/caen/3: never do downgrade, unless KORG said it is okay, and HOW. do not do that.guessing EVER.4: ask them. only They know, or find a real KORG forum we are NOT.like here?https://www.korguser.net/login.asp?OS=WIN&LAN=1&TOP=1ask there .
7/20/2022 6:47:23 PM • Korg Computers &... • Answered on Jul 20, 2022
I have Korg D888 which I accidentally disconnected while it was in usb slave mode. Now the iMac computer won't recognise it at all . Any suggestions
Re boot the Korg and iMac. Reattach the USB cable and wait for connection.
11/21/2021 12:56:33 PM • Korg Computers &... • Answered on Nov 21, 2021
Korg ax5g blinking rapidly upwards and doesn't work
Did you solved this issue ? I have the same problem.
8/11/2020 11:57:43 AM • Korg Computers &... • Answered on Aug 11, 2020
I have korg n364 keyboard POWER SUPPLY smps of this keyboard TOTALLY damaged. I want to buy new power supply smps
Look at the output voltage and amps and search amazon for the same spec power supply or search ebay for a n364 power supply
5/3/2019 7:25:34 AM • Korg Computers &... • Answered on May 03, 2019
Korg (KCDRW1X8X) CD-RW Burner Logo
9 questions posted
Top Korg Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
SmartAviator
SmartAviator
Are you a Korg Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Korg Computers & Internet
Most Popular Question
korg triton studio cd burner locks up
  • Computers & Internet
